Vertical Multicolored Lines Viewsonic LCD
  • storexxm
    • Oct 2012
    • 107
    • Vienna
    Hello to everyone.
    I got a broken Viewsonic LCD here.
    As i wrote in the topic, when i turn on the LCD only
    bright vertical lines (in blue green red) are viewable.
    (they are getting brighter at the beginning... like a cap is getting loaded)
    Here a picture of the Lines and some caps from the board which is connected to the display (seems to be for the lcd lamps... but the bright lines look more than a data connection failure ?)
    Hope someone got an idea =)
  • Rtech
    • Jul 2010
    • 1095
    Re: Vertical Multicolored Lines Viewsonic LCD
    You will probably find that you need a new Screen.
    • tibimakai
      • Jan 2012
      • 3680
      I have fixed a 42" Vizio Tv with a similar looking problem and it was the famous U33 vdo on the mainboard.
      • Alohamora
        • Aug 2012
        • 37
        What does it look like when you have a video source hooked up? Do you get any video? Do the lines always stay in the same spot or do they move around?
        • storexxm
          • Oct 2012
          • 107
          • Vienna
          Hello.
          The picture was while the video cable was connected.
          I also activated the 2nd display in windows and moved a window on the broken screen... but the lines didnt move.
          The only thing i saw is, that the lines where "moving" when i turn the sceen off and on again.. -> so the lines don´t move in that way, but are always on another position when i turn it off and on (also the color varies)
          @ Rtech - i got it broken from my office, so its more the curious, then i need it.
          @ tibimakai - what do u mean with u33 vdo (already googled it, but no logic results ^^)
          SORRY 4 MY POOR ENGLISH !
          • jetadm123
            • 2169
            You can try cleaning and reseating the flat ribbon cable that connects the logic board to the LCD panel.
            • Alohamora
              • Aug 2012
              • 37
              Originally posted by storexxm
              Hello.
              In my experience (which is entirely with one particular brand of LCD TV) that would more likely be the LCD timing control board, or even the main board, than the LCD panel. A bad cable connection is also possible.
              • Gariarto
                • Jul 2012
                • 151
                Try applying some squeeze pressure by the offending lines from the outside of the case, or better still directly to the panel. Like, pinching it. Does anything change ? If so, it may be the panel de-laminating, in which case it has to be replaced. If no changes are affected by doing this then pursue the cabling connections and control board.
                  I'm betting on low 5V or 12V to the t-con; I've seen it before on a TV.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    The U33 component is a voltage regulator that delivers 3.3V to other components on the mainboard. This is on some Vizio TVs. Check all the voltages, see if none of them is a bit lower than it should be.
                    • storexxm
                      • Oct 2012
                      • 107
                      • Vienna
                      i already disassembled the hole screen....
                      have to try what happen when i disconnect the small ribbon cable... if there are those lines too...
                      @ tibimakai - ok, i will do that next weekend
                      So nobody thinks the green caps maybe can be the issue?
                      • storexxm
                        • Oct 2012
                        • 107
                        • Vienna
                        So i disassembled and assambled the whole monitor, same thig happen.
                        Vertical bright colored lines.
                        The voltage on the power board are correct.
                        I made some pictures again, maybe someone can tell me which component could be broken ?
                        Uploaded with *************
                        • tibimakai
                          • Jan 2012
                          • 3680
                          What I was refering to is a VIZIO TV. You have on the mainboard a U3 and U5, check those to see what kind of voltages do you get at each pin.
                          There is a T-con board somewhere? Pictures?
                          • storexxm
                            • Oct 2012
                            • 107
                            • Vienna
                            Hello.
                            In the wohle monitor were only those 3 Boards... (the yellow and green one are connected by the power connection)
                            The number after the U stands for something or is only numbered?
                            Or is there another board where i put the other side of the data cable?
                            (never looked up there...)
                            add:
                            Okay i googled it.. damn... never tried to open the rest of the case
                            Is it possible to repair a t-con board ?
                            • storexxm
                              • Oct 2012
                              • 107
                              • Vienna
                              Here are the pictures of the t-con board. the ribbon cables are glued with the panel...
                              any ideas... ?
                              • storexxm
                                • Oct 2012
                                • 107
                                • Vienna
                                i pressed on the ribbon cables during the screen was connected... no lines moved.... seems like the t-con board or the video board is dead
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  You are likely to get more help if you stop posting pictures in line- please post them as attachments. Also try and get the whole board in the picture.
                                  On the T con there is what looks to be a fuse but its cut off the picture.
                                  It is white, if it is a fuse, please test the voltage on both sides of it.
                                  You should also test and post the voltages on the regulators.
                                  The numbers following the "U" do not signify a value they are the board designation numbers - Instead fo saying the "Green Capacitors" you should be saying capacitor at Cxxx on the main board so we know exactly what you are talking about.
                                  The numbers also need to be visible in the pictures.
                                  EDIT there may be another fuse near the white one - perhaps green
                                  as I think I can make out F3? if so it suggests there are at least 3 fuses on that panel board (Tcon) look for F1 - F2 -F3 and so on.
                                  • Stanley1843
                                    Screen Display Vertical Multicolor Lines
                                    by Stanley1843
                                    Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                    06-29-2024, 11:54 AM
                                  • visionbluedemon
                                    Help. Sony kd-65x85dj vertical lines
                                    by visionbluedemon
                                    First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                    Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                    tried blocking LC lines too, but same results
                                    is it lcd panel issue or tcon board issue?...
                                    07-25-2025, 04:56 AM
                                  • gpo23
                                    Sony KDL-40V3000 - Vertical lines
                                    by gpo23
                                    i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                    With the new t-con the color are good but there are vertical lines on all the screen :
                                    I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                    Is there a way to fix the vertical lines on the new t-con ?
                                    Thank you for your help
                                    gpo23...
                                    10-04-2023, 09:11 AM
                                  • Firentiosi
                                    1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                    by Firentiosi
                                    Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                    The issues are as follows: the...
                                    11-27-2024, 12:33 AM
                                  • viking509
                                    vizio e65 e3 LED tv color vertical lines center tv only
                                    by viking509
                                    I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                                    03-21-2023, 12:48 AM
