Bob Parker ESR Meters
  • akuhon
    • Feb 2007
    • 5
    #101
    Re: Bob Parker ESR Meters
    Hai Bob,
    I just got your device ..... it's really helpful.
    I'm identifying several capacitors available from the electronic market component .....
    So, now I'm not a afraid of counterfeit / fake / rebadge product....
    Here's Rubycon cap... the device give the same result as the datasheet (0.046 ohm) ...
    But I also see, in every capacitor's datasheet, there's a measurement of ripple current (mA r.m.s.)
    Do you think this measurement is also important ?
    How to do it, any idea ? Or maybe you can make it, combine with your existing ESR Meter for the next version (Mk.III) ?
    Cheers,
    • Bob Parker
      Technician
      • Feb 2007
      • 182
      Originally posted by tazwegion
      Unfortunately, I missed the sale on that particular version T2200 (meter), but I did land it's little brother T1976 (minus meter), BTW thanks for the pointer(s) always appreciated
      The 17w ~ 25w hobbist irons are quite nice IMHO, but their tips don't make fine/detailed soldering easy by any means... but I digress
      Temperature controlled irons (set to a sensible temperature of course!) are almost essential when you're working with PCBs. Uncontrolled irons are OK for tinning the ends of bits of cable etc which are pretty hard to damage with excess heat.
      It is a good shrubbery. I like the laurels particularly...
      • Bob Parker
        Technician
        • Feb 2007
        • 182
        Originally posted by akuhon
        Hai Bob,
        Cheers,
        The data sheets generally tell you the highest ESR which can be expected for a specific capacitor type/model. Mostly they're a bit below that figure at 25 degrees C.
        ESR is a very variable kind of thing, and don't forget that it changes quite dramatically with temperature (ESR drops as temperature rises). This is one reason why it's better to check capacitors in-circuit if possible. Otherwise the heat from de-soldering them makes the ESR decrease until they cool down again, making them look better than they really are.
        Ripple current is a maximum rating for a capacitor. It's the largest AC current you can safely pass through it. That's what mA RMS means. It's like voltage rating .... it's about what the circuit's doing to the capacitor, not a characteristic the capacitor itself has.
        • akuhon
          • Feb 2007
          • 5
          #104
          Thanks Bob,
          That helps ......
          How about a new / fresh (never used) caps ? If I test with this ESR meter, will the result be valid ?
          Thanks ...
          • Bob Parker
            Technician
            • Feb 2007
            • 182
            Thanks Bob,
            That helps ......
            Thanks ...
            I'm not really an 'ESR Meter Guru' . I'm just a technician who was repairing switching power supplies and I desperately needed to know the condition of their capacitors. I'm not an expert on every detail of electrolytic caps. I can only tell you my experience after using the ESR meter since 1995.
            Most new electrolytic caps have an ESR a bit below what their datasheets say. It will stay low for a very long time unless the capacitor has been operated at a temperature considerably above room temperature, especially if it has high ripple current through it.
            Of course this doesn't apply to the billions of faulty electrolytic caps which are the reason that this Badcaps forum exists! They will keep getting worse as long as they have DC across them.
            So the ESR of an unused electrolytic cap will be very similar to what it would be if it had been in use for a while, under normal temperature/ripple current conditions.
            There is a lot of information about electrolytic caps and what to expect when using an ESR meter in the kit notes for the Dick Smith ESR meter. Anyone can download it from
            But I don't have time to answer lots and lots of question about it.
            • akuhon
              • Feb 2007
              • 5
              #106
              Hi Bob...
              Thanks for your comment and I really thank you for making this great device.
              Cheers,
              • starfury1
                • May 2006
                • 1256
                #107
                Hi all
                A page on capacitance and ESR Here
                Bit on the techie side and uses maths you may have to search out the definitions of some terms, properties to make sense of it.
                heres another page with links off it including Bob Parkers page
                ESR Testing
                Hope it helps anyway
                Cheers
                You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
                • PeteS in CA
                  • Aug 2005
                  • 3579
                  • USA, Unsure of Planet
                  #108
                  Lytic caps' ESR have a strong negative tempco - lower ESR at higher temp and higher ESR at cold temps. Caps with water-based electrolytes are typically only rated down to -40C, while non-aq low Z types are typically rated down to -55C. At 25C, good low Z caps have a lower Z/ESR than their max rating. Theoretically, the ripple current rating means that if you run caps above that rating, hydrogen gas will be produced, leading to premature failure. I don't recommend exceeding that rating on a long-term, full-time basis, but it is a conservative rating. I've run caps in one of my tests at multiples of their ripple current rating (at room temp) and had some last for thousands of hours. Re discharging caps, I have a jig made of two power resistors in series formed like tweezers so I can discharge the caps I'm testing while gripping the resistors by their bodies (IOW, I don't get zapped, ). I discharge every cap (and let them cool for two hours - it's an engineering tests) before checking them on my LCR meter.
                  PeteS in CA
                  • Bob Parker
                    Technician
                    • Feb 2007
                    • 182
                    I've just done a whole lot of net searching to find out more about ripple current causing hydrogen liberation in electrolytic caps and can't find a thing. The manufacturers say hydrogen generation is a function of DC leakage, and ripple current simply causes I2R heating.
                    Can you please direct me to more info on this subject? Thanks.
                    • PeteS in CA
                      • Aug 2005
                      • 3579
                      #110
                      Wellllllllllllllll ... these two pages from UCC say it indirectly:
                      http://www.chemi-con.com/u7002/life.php
                      http://www.chemi-con.com/u7002/failure.php
                      The failure chart points out that excessive ripple current causes increase internal pressure. The life page points out that excessive ripple current causes oxide formation on the cathode foil. Hydrogen gas is a byproduct of oxide formation and the cause of the rise in internal pressure.
                      PeteS in CA
                      • Bob Parker
                        Technician
                        • Feb 2007
                        • 182
                        Hmmm, OK. Thanks for that.
                        • Bob Parker
                          Technician
                          • Feb 2007
                          • 182
                          Hi Bob...
                          Cheers,
                          I'm happy that this meter I originally only designed for me is useful to lots of others who are having problems with Bad Caps.
                          Just for everyone's information, Dick Smith Electronics down here in Australia has completely gotten out of the kits business. No more ESR meters are going to be produced.
                          Most of the remaining stock of them is now at John's Jukes in Vancouver, Canada. He ships world-wide and his prices and customer service are good.
                          His website is at http://www.flippers.com
                          • K7214
                            • May 2007
                            • 1
                            #113
                            Bob Parker's ESR kit still available!
                            Caution - blatant, self-serving ad!
                            If anyone here is looking for the Dick Smith (DSE) K-7214 ESR kit for measuring electrolytic capacitors in circuit please feel free to visit:
                            http://flippers.com/esrktord-form.html for more info.
                            I have about 150 left in stock.
                            John :-#)#
                            PS, for those of you that already have the kit Bob set up a poll to find out if folks wanted the meter continued as a kit or pre-assembled you can find it at the top of our ESR support page:
                            http://flippers.com/esrkthnt.html
                            • Sp@rtacus
                              • Oct 2011
                              • 1
                              #114
                              Hi, can you help me with a HEX file for blue esr for microcontroller??
                              • dumpystig
                                • Jul 2011
                                • 485
                                ESR... ripple current... hydrogen liberation...
                                Christ, we're talking about one type of many different components on any PCB - basically if it looks buggered or I think it may be buggered then I replace it, sometimes on a somewhat trial-and-error basis, but almost always with success.
                                System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4951
                                  • New Zealand
                                  #116
                                  I doubt that is going to happen any time soon.
                                  Look on Google, there are many other ESR meter designs available and with source code, if you want to make something yourself.
                                  -David VanHorn
                                  • Sparks88
                                    • Sep 2011
                                    • 110
                                    #117
                                    hi, i would like to find the blue esr meter for sale in the uk or europe, this is because anything from the US will get me hammered by the dreaded vat and import duty then royal mail also get their pound of flesh, any info appreciated.Thanks in advance.
                                    • Bob Parker
                                      Technician
                                      • Feb 2007
                                      • 182
                                      I don't know if it's of any use to you, but the EVB ESR meter from Portugal is almost the same as the Blue meter from Anatek Corp. Its web page is at http://clientes.netvisao.pt/greenpal/evb1.htm
                                      • Sparks88
                                        • Sep 2011
                                        • 110
                                        #119
                                        Thank you, i was concerned about charged caps but i see that the meter can be ordered with protection diodes.
                                        • ksor
                                          • Apr 2015
                                          • 13
                                          • Denmark
                                          #120
                                          Has any of you experiences with the ERS meter kit "K 7214" from this firm:
                                          Good or bad ?
                                          Best regards
                                          KSor, Denmark
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                          • flibidy
                                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                            by flibidy
                                            I have here a Magnum IA.100 which belongs to my parents.
                                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                            What Ive done........
                                            01-01-2025, 01:26 PM
                                          • eccerr0r
                                            lowest current galvanometer/analog meter (passively powered!)
                                            by eccerr0r
                                            Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                                            On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                                            04-16-2025, 12:41 AM
                                          • chth96
                                            How Can I test PWM DM0365R?
                                            by chth96
                                            Hello
                                            I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                            So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                            I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                            I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                            06-18-2025, 04:14 PM
                                          • khelane
                                            test active pfc power with lamp test
                                            by khelane
                                            Hello
                                            I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                            Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                            Is there a way...
                                            06-03-2025, 01:00 AM
