Comments on The Recapping FAQ
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Here is a place for the comments to the Recapping FAQ
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Originally posted by willawake
    Solder Sucker / Soldapult (Standard Size)
    This is the only part I find objectionable. I HIGHLY recommend NOT using mechanical solder suckers on motherboards! I've seen many people destroy their boards with them, typically when it recoils and impacts the board, knocking the traces off or sucking the lead port out of the PCB. If you don't have access to a pneumatic or vacuum solder sucker, use solder braid or a needle pick. The pick works best for me, I can clear a hole faster with the pick than one can with a pneumatic solder sucker.
    VERY nice writeup!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      hmmm, i guess you are right, there is a concern. I did every board with the solder pump though and there was no probs. i am holding it flush against the board and the board is supported by the board holder. then I hit the switch which makes suction against the board and then quickly take the iron off the back of the board causing the solder to get sucked through. there is no impact against the board but maybe the pressure with the suction could damage a trace. Indeed the lead port could get sucked out.
      Perhaps we can put all the methods with their pros/cons/dangers in the faq
      isnt there also danger in damaging the lead port with the needle pick?
      guess i have to splash out on a rework station someday.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        VERY nice writeup!
        agreed on both counts.
        btw i had to rework a board from a mitek edm where a previous tech had used a soldapult.
        had a short on +5 he couldnt find.
        turned out to be a crumb of solder lodged between 2 pins of an ic.
        there are some things a soldapult is ok for.for everything else theres ungar,weller,hakko,ect.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          ok agreed. For the people on low budgets, is a desoldering bulb the best choice then?
          TC : i need to edit the "ghetto cap replacement tips" to remove reference to soldapults.
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            You should be able to edit the post. Let me know if you cant.
            Team : 49813
            Join in!!
            Team Stats
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              no can do. just throw it in the mods section and i will finish the recapping faq instead.
              • yanz
                • Nov 2004
                • 910
                i use tc "dental pic" method and it rocks! btw i use goot/taiyo solder iron... 40w is hot enough and i found no problem.
                days are so short when you actually do something..
                • bgavin
                  • Jan 2007
                  • 1355
                  Re: Comments on The Recapping FAQ
                  MCM offers a number of Tenma adjustable solder stations that are affordable to the hobbyist.
                  Could you experienced buys recommend what features are desireable for this level solder station? For example, I gathered that 60w + chisel tip are good. The Tenma stations are only 48w, and rated to 800F maximum.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    the bargraph and digital versions are decent.
                    i own one each.
                    the desoldering station is fragile and maintainence intensive.
                    my old(antique) ungar is 10x better.
                    • StigOE
                      • Mar 2007
                      • 8
                      Hi.
                      I'm a new member, but I have a comment about the temperature recommended for soldering the caps. I'd say 450C is way too high. When I had my soldering courses (first halves of the 90's), a rule of thumb were approx 150C above the melting point of the solder. Since normal 60/40 solder have a melting point of 177-183C, a good temperature would be about 350C. If you need as high as 450C, either you don't have a powerful enough soldering iron or a too small tip. With too high temperature it's a lot easier to damage the tracks due to disbonding. Too powerful soldering iron/too big tip/prolonged heating is no good either...
                      Stig
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        I solder at 350°C and desolder at 400-450°C
                        • stavr0
                          • Nov 2007
                          • 21
                          5.5. Remove the capacitor
                          Gravity is your friend: Resting the board upside down, I clamp the bad cap with a needle-nose plier with an elastic band around the handle. Heat up both leads alternatively every few seconds until it falls off under the weight of the pliers.
                          • severach
                            • Aug 2007
                            • 1055
                            The cheapo solder stations don't have good heat recovery so they need to run at a high temperature to have enough heat to withstand the shock of cold parts. A good solder station can do the same work much better at a much lower temperature.
                            What I'd like to find is a needle nose with a curved jaw and a close spring. It would resemble some of the spark plug pullers and does not need to be strong. The jaw should be silicone tipped and thin enough that I can correctly position a cap in the middle of other caps underneath a wire bundle.
                            sig files are for morons
                            • bobbyrae
                              • Jun 2013
                              • 25
                              Originally posted by StigOE
                              Hi.
                              Stig
                              I have to agree with this. I have a Hakko Soldering station that got out of calibration for a while. I was recapping an old stereo system and I burned up a couple of pads before I realized what was going on. It had to be up around 400 degC. Of course I haven't dealt with computer motherboards yet, but I just can't see setting the temp that high because I have been able to desolder everything fine at lower temps.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                It's because motherboards often have large traces... like ground planes. and multiple layers of traces. they act as heatsinks, sucking away the heat put out by your iron. So yes, you do need to set it that high.
                                sigpic
                                (Insert witty quote here)
                                  Wattage is also important, to work on mother board, you will need 60 watts, you can have two soldering irons that can have the same temp, the lower wattage one will will lose it temp quickly when makes contact with the object you are trying to solder.
                                  • howardc64
                                    by howardc64
                                    07-24-2025, 05:17 PM
                                  • howardc64
                                    by howardc64
                                    Problem
                                    08-04-2024, 10:36 PM
                                  • Hakuu
                                    by Hakuu
                                    Hi There,
                                    More Details
                                    TV Model - LG OLED77G1PUA
                                    07-12-2023, 02:37 PM
                                  • m1ch43lzm
                                    by m1ch43lzm
                                    05-12-2025, 08:37 PM
