Different Types of Capacitor Mounting
This is a sticky topic.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    • Electronics Repair
    There are several different types of capacitor mounting configurations and also capacitor types. The most common type for motherboard applications is radial lead/radial wire ended.
    Aluminium Electrolytic Capacitors - Radial Lead
    An example : Panasonic FC capacitors which are radial lead. This means that they have two leads + and - coming out of the capacitor on the same end. The negative lead is the shorter one and also indicated by the stripe down the side of the capacitor which also shows a - symbol, repeated along the length of the capacitor. The photo shows capacitors as you would receive them new with the full length of leads that you can cut to size. These capacitors are Aluminium Electrolytic which means that there is probably two layers of aluminium foil which are separated by paper that is impregrated with an electrolyte gel. The layers are then wound and enclosed in an aluminium or plastic tube. You can clearly see in the photo the capacitor bungs at the bottom of the capacitor. On good capacitors like the Panasonic FC they are made of EPT (Ethylene Propylene Rubber) which is a synthetic material. On the bad capacitors for cost reasons, natural rubber is used. This gets hard with age and the failure of the electrolyte can bust the bung out of the bottom of the cheap caps, leaking electrolyte on your nice smd components.
    Axial Lead
    This means that one lead is at each end of the capacitor.
    Surface Mount Chip Type Capacitors
    Surface mount chip capacitors on an Asus video card. See their black surface mount seats which are at the bottom of each cap. The black mark on the silver top of the cap indicates the negative lead. The seat is also square at the negative side. It is not clearly apparent from the markings, who manufactured these caps. Why would they use these surface mount chip capacitors instead of normal radial lead capacitors? Well it is easier to place and solder them to the board with machines.
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
    Subscribe to support us. It only takes 1 minute:
    <url=https://www.badcaps.net/settings/subscriptions>https://www.badcaps.net/settings/subscriptions</url>
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Surface Mount Capacitors
    Very small components which are soldered to one side of the board, either at the front or the back.
    The above image shows the ceramic smd capacitors positions with the numbers preceded with CB or C. The resistors position numbers are preceded with R.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Surface Mount Tantalum Capacitors
      As indicated by the orange arrows. They come in case sizes A,B,C,D,E. The small ones in the photograph are B and the larger one is D. The bar on the cap indicates the POSITIVE side. These were used in motherboards, graphics cards, lan cards etc. I did not see them used after geforce1 though.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        need help with this thread guys....
        • TheInfamousJerry
          • Jun 2005
          • 15
          Re: Different Types of Capacitor Mounting
          Free-Standing Capacitors
          These are very popular among AMD users. These suckers will power up to an Athlon XP 2400! Installation is simple, bolt the capacitor to the side of your case, preferrably with a U-bracket and weld the leads to the most convenient and accessable area!
          Note: Don't do this! This post was merely a joke! Neither me nor the board moderator nor owner should be held responsible if you wire a huge capacitor to your board, rendering it(and probably yourself) inoperable!
          I helped!
          • kc8adu
            • Nov 2003
            • 8836
            • U.S.A!
            all jokes aside those large screw terminal types are commonly called computer grade.
            my imsai 8080 has 2 of them.
            the smaller ones in the center are snap ins.
            used in some pc psu.
            I helped!
            • arneson
              • Sep 2005
              • 1267
              • Boating, Electrical Eng.
              Why the disclaimer saying not to do this?
              It's not merely a joke.
              I have lined the inside of my case with these big boys and she's stable.
              But it takes an hour for the power light to go off.
              Jim
              • PeteS in CA
                • Aug 2005
                • 3591
                • USA, Unsure of Planet
                • Reading, Education, History, Christianity
                One of the nicknames for a computer grade types is a "beer can" (though some are more the size of a V8 juice can. Some larger snap-ins have an extra terminal or two to improve mechanical stability.
                PeteS in CA
                • OldeCrow
                  • May 2005
                  • 18
                  if you don't want to power your computer with them they are fun at parties too
                  • triplelatte
                    • May 2006
                    • 10
                    I have something close to that in the trunk of my car. I use them to store power for my amps so when the bass hits my light don't dim. the brand is lightning caps and they pack a punch to them. a friend of mine damn near blew his hand off messing with his .
                    • Gendo Ikari
                      • Jun 2008
                      • 62
                      I accidentally knocked one of these off an old ISA 10Mb network card I got from a guy. I was wondering what the heck it was. At least I can maybe replace it now if I really want too.
                      • gonzo0815
                        • Feb 2006
                        • 1600
                        Tantalum capacitors.
                        • Moopy
                          • Jan 2015
                          I'm new here and was looking for a nice spot for my first post and stumbled across this thread of knowledge. I've seen tons of these types of capacitors but I never knew their technical names. Now I just need to learn about diodes.
                          • jentoris
                            • Jun 2015
                            • 49
                            • Indonesia
                            that yellow capacitor is the smaller size of caps and give you the most stabel power output than the other caps pictured, and also it's more expensive.
                            • joetristan
                              Tantalum capacitor burning out
                              by joetristan
                              I’m using a 10 µF, 20 V tantalum capacitor as a decoupling capacitor across a 5 V supply. When I power the circuit, the capacitor burns out.
                              At first, I assumed the tantalum capacitor was defective and replaced it, but the new one burned out as well when the circuit was powered.
                              I then replaced the tantalum capacitor with a 10 µF, 63 V electrolytic capacitor. This time, the capacitor did not fail after powering the circuit.
                              I do not understand why the tantalum capacitor burns up?
                              02-11-2026, 03:43 AM
                            • jkucukov
                              ASUS Zenbook 13 Laptop UX333FN Need Help with SMD Capacitor Identification
                              by jkucukov
                              I have a ASUS Zenbook 13 UX333FN motherboard that I need to replace a SMD capacitor. This SMD capacitor is located on the back side of the motherboard and is really small (C0201), however I need to find the specs of the capacitor (Voltage rating and Capacitance).
                              I was fortunate to find Boardview file for however all I was able to get from the file is the Capacitor reference designator (C6353), here is the information:
                              How would I be able to get Voltage rating and Capacitance of the SMD Capacitor?
                              Thanks,...
                              08-11-2026, 09:00 AM
                            • Prolog
                              by Prolog
                              12-01-2024, 08:27 PM
                            • woodboy971
                              Need help – Identifying missing capacitor (HP CM 6050A2892401 MB A01)
                              by woodboy971
                              I am a beginner in electronic board repair and I am looking for help with an HP motherboard: CM 6050A2892401 MB A01.
                              Initially, the laptop would not power on. After troubleshooting and taking measurements, I found that a capacitor was shorted, which was preventing the system from starting. I removed this capacitor.
                              After removing it, the PC now powers on for a few seconds and then shuts down. I believe this behavior is related to the missing capacitor, which is no longer performing its role in the circuit.
                              My issue is that I cannot identify...
                              12-27-2025, 10:31 PM
                            • Quadro1000
                              MXM Graphic card Nvidia Quadro K1000m /K2000M schematic or value of capacitor C55 capacitance and voltage from laptop HP8570w
                              by Quadro1000
                              I had a MXM graphic card type Nvidia K1000m from laptop HP8570w which had a broken capacitor.
                              The ceramic capacitor seems was broken and makes a short circiut. The laptop goes off because of the short-circuit. But it seems currently that only the capacitor C55 was broken on the graphcic card.
                              Because after I have desoldered it, the laptop runs with the card. But currently without this capacitor.
                              So to have full functionality and no instabilities I want to replace it with a new one.
                              So I need to know the value and voltage of C55 to replace...
                              12-16-2025, 11:17 AM
