Lithium Ion Battery Manufacturer Links
  • japlytic
    • Oct 2005
    • 2086
    Since we have had a number of reports of faulty lithium ion battery packs (particularly Sony ones), there should be a list of lithium ion battery manufacturers:
    Panasonic: www.panasonic.com.sg/industry/
    LG Chem: www.lgchem.com
    Samsung: www.samsungsdi.com
    Sanyo: www.sanyo.com/components/
    I am still looking for manufacturer links for Toshiba and Sony lithium-ion cells.
    Anyone who knows of other lithium ion battery manufacturers, place the manufacture links here!
  • arneson
    • Sep 2005
    • 1267
    Re: Lithium Ion Battery Manufacturer Links
    When I needed button cells I went with this company.
    Good spec sheets and sent samples when I asked.
    http://www.nordic.varta-microbattery...ages/index.htm
    Jim
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
      by sam_sam_sam
      I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
      I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
      12-31-2023, 06:04 AM
    • mkdj
      ASUS X571 no power : battery issue?
      by mkdj
      Mark and model: ASUS X571
      Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
      Tests already made:
      - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
      - I have removed...
      07-14-2025, 09:16 AM
    • budwich
      Lithium 12v tool battery charger... no negative connection?
      by budwich
      I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
      03-18-2025, 09:12 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
      09-14-2023, 11:10 PM
