Lithium Ion Battery Manufacturer Links
  • japlytic
    • Oct 2005
    • 2086
    • Valve/tube stuff, cartoons
    Since we have had a number of reports of faulty lithium ion battery packs (particularly Sony ones), there should be a list of lithium ion battery manufacturers:
    Panasonic: www.panasonic.com.sg/industry/
    LG Chem: www.lgchem.com
    Samsung: www.samsungsdi.com
    Sanyo: www.sanyo.com/components/
    I am still looking for manufacturer links for Toshiba and Sony lithium-ion cells.
    Anyone who knows of other lithium ion battery manufacturers, place the manufacture links here!
  • arneson
    • Sep 2005
    • 1267
    • Boating, Electrical Eng.
    Re: Lithium Ion Battery Manufacturer Links
    When I needed button cells I went with this company.
    Good spec sheets and sent samples when I asked.
    http://www.nordic.varta-microbattery...ages/index.htm
    Jim
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      12-31-2023, 06:04 AM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • budwich
      Lithium 12v tool battery charger... no negative connection?
      by budwich
      I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
      03-18-2025, 09:12 AM
    • Moosiv
      Acer Nitro 5 - Battery Not Charging
      by Moosiv
      Laptop: Acer Nitro 5
      Board: GH53Z LA-L031P Rev: 1B
      Charging IC: Texas Instruments BQ24781 (PUB1) Fault
      Battery is detected correctly by the EC/Windows but will not charge.
      Originally the laptop would boot and run normally on the AC adapter only, but the battery would never charge. Battery percentage remained static and BatteryInfoView reported a charge/discharge rate of 0 mW.
      Initial Measurements
      Battery voltage: approximately 15.5V
      BQ24781 measurements:
      • VCC = 19.2V
      • ACDET = 2.5V
      • REGN = 5.9V
      • ACOK = 3.2V
      • SDA
      06-25-2026, 08:59 AM
