Mouser replacing Xicon caps with Lelon?
  • Peale
    • Apr 2009
    • 96
    I repair arcade monitors, and as such have used the Mouser lists to order just what I need for a specific monitor at the click of a button.
    When I went to order some today, I was told this:
    The Xicon series of Aluminum Electrolytic Capacitors are obsolete. These products will be replaced by product from Lelon Electronics Corporation. Most changes, if any, are cosmetic in nature (sleeve color, sleeve text, etc.).
    Once stock has been depleted, this part will no longer be available. Mouser has added a suggested replacement for the original item. It is recommended that the specifications on both items be reviewed to assure the replacement part can be used in the application. 5-0210-14
    This upsets me a bit as I've had really good luck with Xicon as a company. And I note that Lelon is on the "bad caps" list.
    • 31278
    Re: Mouser replacing Xicon caps with Lelon?
    i repair arcade monitors too,
    and i wouldnt use either of those brands.
    i NEVER want to see a chassis i have repaired again - ever.
    using brands like that are likely to bring the chassis back after a year or 3.
    we both know how poorly cooled most arcade cab's are.
    • Peale
      • Apr 2009
      • 96
      I've never had an issue with Xicon caps. Most of my jobs are still out there on the street, years later.
      • Krankshaft
        • Jan 2007
        • 2328
        Lelon is definite crap if Lelon was manufacturing Xicon then my instincts were right to stop using them. I used them a bit in the beginning before ditching them for Panasonic and Chemicon.
        Check out either Panasonic, Nippon Chemicon, or Nichicons cap lineups they are way better than those Xicon ever were.
        All the brands above are high quality Japanese cap manufacturers. Who most importantly don't skimp out on the aluminum purity for their caps plates.
        If you use General Purpose caps alot which to my knowledge is all Xicon manufactured I'd recommend the Nippon Chemicon KMG series they are well made 105C GP caps. I always bought them from Newark.com but Mouser has them too. Just type Chemicon KMG in the search field.
        If you are recapping the power supply sections though and they use switching PSUs instead of linear PSUs you'll want a low ESR series on the secondary like the Panasonic FC series for example.
        I've never used Xicon but I do know that their 85C GP series has a sky blue sleeve and their 105C GP series has a radioactive green sleeve. Come to think of it Lelon uses the same color for their 105C.
        • Krankshaft
          • Jan 2007
          • 2328
          Man I can't believe Mouser would actually stoop so low as to sell that Taiwanese crap brand.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Xicon are good caps but little or none available in the way of low ESR.
            They choose their 'equivalents' totally by data sheets which doesn't reflect the actual quality of the product.
            In other words the bean counters at Mouser are F*cking stupid because they have no real world experience.
            Pass on the Lelon.
            Switch to Nichicon or Chemicon.
            Those are probably both better ESR AND cheaper than Xicon was anyway.
            Mann-Made Global Warming.
            - Dr Seuss
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              guess who i'm not buying from! (if the shipping hikes weren't enough of a turnoff)
              damn marketing dummies... they should have learned the lesson about having salesmen do an engineer's job from apple, the original macs and the original apple /// were both fanless-- to make them quiet-- but they got so hot they would warp floppy disks and desolder parts off the mainboards. an engineer would have known better, but the marketing idiots had no idea... and mouser has made the same blunder with cap quality...
              sigpic
              (Insert witty quote here)
              • blowing_in_the_watts
                • Jul 2010
                • 21
                i was disappointed to find lelon on mouser also
                as i had just removed a dozen or so + elite off a monitor psu
