Sony XBR-65X930D No screen
  • yankys
    replied
    Re: Sony XBR-65X930D No screen
    @ fp1 fuse it only shows 0.6mv on both ends of the fuse.
  • yankys
    replied
    I will check this as soon as I get back to the house and post my findings thank you.
    replied
    while powered up, see if theres about 12 volts on each side of the tcon fuse, neg. probe on chassis ground, pos. probe on each side of fuse.
  • yankys
    started a topic Sony XBR-65X930D No screen
    HI, everyone I want to say thanks for the help on the samsung. now it's my sons Sony XBR-65x930D I am trying to fix I've replaced the dps and main board did the firmware update, now I have the white light on bottom of the tv and it seem to turn on and off but no picture not sure how to precede could some possibly point me in the right direction.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • misterhaus
    Sony XBR65x930D - left half screen is grainy
    by misterhaus
    Hi, this is my first post - so thanks in advance for any assistance.
    I have a Sony XBR 65x930D (manufactured in July-2016), which was initially showing a black screen, faint backlight glow, and played musical sounds when powered up. After some experimenting (mostly unplugging cable and re-plugging), including attempting hard-reset and firmware update, it is now showing video, but the left side of the screen is fuzzy/grainy. (See attached pic)
    I am trying to decide if this could be the T-CON board, or the DPS board.
    When I press on the upper right of the DPS...
    03-16-2020, 04:33 PM
  • Chrissygizmo
    Sony KD-55XG9505 lines on screen problem
    by Chrissygizmo
    Hello again everyone,
    This is my latest mission, to try getting this Sony tv back to normal working order…
    I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
    02-19-2025, 11:31 AM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
