Sony KD-43X8309C
  • tehmatix
    • Nov 2012
    • 174
    Sony KD-43X8309C
    This tv is coming with no light at LED standby, no picture, no sound.
    When power button is pressed nothing is change
    I checked the power board and found 3.3V and 12V.
    I made allready a hard reset with volume- and power button .
    Any ideeas ?
  • tehmatix
    • Nov 2012
    • 174
    Re: Sony KD-43X8309C
    Hello guys, any ideas will be helpful !!!!!
      • 12181
      • U.S.
      can you post good straight on pictures of each board and one of the whole back, as to see how everything is connected.
      • tehmatix
        • Nov 2012
        • 174
        Pictures of the tv
          • 12181
          • U.S.
          can you get a clear close picture of the map/legend right there by R6410, maybe check all the diodes and resistors on top of the board.
          • tehmatix
            • Nov 2012
            • 174
            Hi
            Could be a backlighting issue? I will check the leds with a tester.
              • 12181
              • U.S.
              ok, also see if you have the ac_detect voltage there on your connector on powerboard, and trace the standby wire back to mainboard and see if you have that 3.3 voltage on the mainboard connector.
              • tehmatix
                • Nov 2012
                • 174
                On CN6401 ac_off_det = 3.475V and standby voltage on the mainboard is 3.475V
                The backlight LEDs are ok and voltage on the rectifier diode(cathode) of backlight power supply is 65.6V
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4326
                  • Italy - Milan
                  Main board is the main suspected, almost 95%, on it near the power connector, that 20 pin soic chip is a PIC16 microcontroller? if yes must be reprogrammed, not sure it solves..
                    • 12181
                    • U.S.
                    does the optical port on mainboard light up when you try to turn on tv?
                    • William1967
                      • Nov 2017
                      • 203
                      • Netherlands
                      Looks like a bad EMMC, in more than 95% the EMMC has reached the "end of life" status and must be changed with a new loaded EMMC.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4326
                        • Italy - Milan
                        Whatching THIS.. and .. THIS.. it seems a proper PIC microC, so i bet for that..
                        THe tv has no signs of life so bad standby SW, that reseats in the PIC..
                        • lotas
                          • Jan 2016
                          • 4595
                          • Russia
                          In these chassis, eMMC Flash and the MediaTek processor (SoC) are mainly dying.
                          • tehmatix
                            • Nov 2012
                            • 174
                            Hi guys,
                            Thank you for your support. From the beginning I suspected the mainboard with a bad eeprom .
                            Indeed, it's a PIC microcontroller on the board PIC16F527. Can be reprogrammed or replaced?
                            If it is a bad EMMC can be replaced?
                            • lotas
                              • Jan 2016
                              • 4595
                              • Russia
                              eMMC
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4326
                                • Italy - Milan
                                must be reprogrammed, two ways to test, first reading it normally, TL866II+ could support maybe, save, freeze the chip, read again, compare dumps, if changes write the second back. Other way, search the web for a dump.
                                • tehmatix
                                  • Nov 2012
                                  • 174
                                  Hi guys, if I will replace the mainboard with a functional one what changes would I need to make?
                                    • 12181
                                    • U.S.
                                    match up the numbers of the white sticker on the replacement board to your board to make sure you get the right one, may have to do a firmware update/pair after you put in new board.
                                    • crackedprint
                                      Sony HCD-HX80R Amplifier Volume Control Problem
                                      by crackedprint
                                      I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                      I have tried a Cold Reset as per the service manual.
                                      I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                      I have looked all the way through the service manual and tried many online...
                                      01-21-2025, 12:18 PM
                                    • Carlos#2003%
                                      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                      by Carlos#2003%
                                      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                      02-15-2024, 07:52 PM
                                    • Ruptor
                                      Sony MHC 6600 volume clicking
                                      by Ruptor
                                      Has anybody had the problem of the digital clicking from the volume control coming through the speakers. I guess the mute should activate as everything seems to have a mute from the analogue switch LC7822 to prevent output of stuff on the speakers but the mute circuits are really complex. The pcb is very badly manufactured as if it is over etched and not cleaned properly before being screen printed because I have fixed one fault but a wide track lifted off real easy with very little heat requiring extra repair. I dread touching the board so would like to go straight to the problem if someone has...
                                      05-21-2023, 05:32 AM
                                    • jason123
                                      Sony STR-DN1030 Distorted audio when Volume adjusted
                                      by jason123
                                      New to Audio equipment. Received this 7.2 Surround Sound system - had a blown channel and fixed that (0.22 ohm resistor, 2 transistors, and 1 100 ohm replaced)
                                      All channels now work. However, when I raise the volume with knob or remote, it doesn't work smoothly - you can heard distortion, and some speakers don't seem to work at max or somewhere in between..
                                      First thought was the actual audio switch - but then Remote volume control shouldn't have this problem, but it does.
                                      Second thought was the ribbon cable from front display to control board (V-Flex,...
                                      06-05-2022, 12:54 PM
                                    • dkneyle
                                      Sony KDL-46HX850 Can't upgrade/update firmware
                                      by dkneyle
                                      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                      09-25-2024, 10:44 PM
