Philips 42PFL6158K/12 stuck on "registering..."
  • CDiazF
    • Aug 2022
    • 13
    • Spain
    Re: Philips 42PFL6158K/12 stuck on "registering..."
    have you asked who you bought the new board off for help ?
    Yep, he just sent me a file to format RWData and something more, I executed that file, then reinstalled the the firmware but no results.
    • Diah
      • Feb 2013
      • 6562
      inter factory mode as described at post #2
      you have there 2 option try one after one
      1- Reset MAC Address
      2- VIRGIN_MODE
      • CDiazF
        • Aug 2022
        • 13
        • Spain
        2- VIRGIN_MODE
        I couldn't enter there with the sequence posted at post #2, all far I went was with the "062596 + INFO / OK" sequence, but in that menu there isn't any of that options, no reset mac address and no virgin mode, not even a hard reset option.
        Is there any other sequences that could enter that options u post?
        Ty!
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4538
          • Italy - Milan
          se l'è inventate sto babba..
          • lotas
            • Jan 2016
            • 4859
            • Russia
            Ty!
            Download the service manual and many questions will disappear.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4538
              • Italy - Milan
              #26
              i remeber those 6xx8 series manual declares "bad cpu>replace board" is it right?
              • lotas
                • Jan 2016
                • 4859
                • Russia
                #27
                No, it says how to get into the service mode correctly and what should be written.
                • Diah
                  • Feb 2013
                  • 6562
                  How to Activate the Factory mode
                  To activate the Factory mode, use the following method:
                  • Press the following key sequence on the remote control
                  transmitter: from the “menu/home” press “1999”, directly
                  followed by the “Back/Return” button. Do not allow the
                  display to time out between entries while keying the
                  sequence.
                  • G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                    by G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                    It does power up when pressing the power button.
                    I already try the power button while plugin the plug with no result.
                    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                    Could this be an PSU or eMMC issue ?
                    07-19-2025, 03:43 AM
                  • Jembang
                    coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
                    by Jembang
                    good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
                    11-01-2024, 09:55 AM
                  • letmealone
                    Smart Tech LE-4048SA stuck at SMARTTV logo: problem solved.
                    by letmealone
                    I had this tv set, stuck at the 'SMARTTV' screen with coloured logo. Impossible to find the original Smart Tech firmware, so i searched in kazmielec.tech some firmware compatible with the tv-set hardware (CV338H-T42 card and Y400HJ6.PE1 screen). The firmware i tried was wrong and it bricked the TV, just showing a black screen and not entering stand by anymore. I supposed it needed special hardware to reflash the NAND, but i was wrong, it just needed a working compatible firmware. Still in the kazmielek page i tried ' CV338H-T42_1920x1080_Telefunken TF-LED43S81T2' and it finally worked. I wrote...
                    09-16-2024, 10:03 AM
                  • Stunt
                    Hp Laptop Stuck on Hp protected by hp sure start screen
                    by Stunt
                    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                    screen that's it and stuck there. I left it until the following day and i still...
                    09-02-2025, 01:51 PM
                  • double_DD
                    Why does my ISP router hate my "homemade" power supply??
                    by double_DD
                    It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                    So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                    For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                    07-12-2025, 03:09 AM
