Hisense F42K20E Hum
  • revenerd
    • Sep 2022
    • 11
    Hisense F42K20E Hum
    With the TV on and not connected to any inputs, I get a hum. Increasing, decreasing, or muting the volume does not change it. It hums through the headphones as well.
    The hum slowly and slightly goes up in pitch, then comes back down. On the blue screen, a click is heard every time the words "no signal" moves.
    If I connect a device to the HDMI port, the hum gets much louder. The video's audio still plays and if turned up enough, it drowns out the hum.
    I read the thread about this model and a static noise. I listened to the audio and it is different than the hum I'm getting. I tried that solution of making sure the boards were clean and I did not help.
  • revenerd
    • Sep 2022
    • 11
    Re: Hisense F42K20E Hum
    I have a little more time to look at this issue. The sound IS more static-like than I remembered.
    When powering on with no devices connected, I get the blue screen with the words "no input" jumping around. The words are motionless, then jump to a new location. On each jump, I hear the static.
    Any change on the screen results in the static sound. I.e. When the numbers change while adjusting the volume, pressing mute, changing the channel, moving around in the menu.
    I muted the TV and the static sound is still there in the same way.
    When I power off the TV, I hear the static for a few seconds after the screen turns off.
    Using an HDMI source with a video, the static becomes constant. Audio is heard, but the static is loud.
    I have reset the TV (static is there throughout the initial setup), increased the brightness to max, removed the power board and cleaned with alcohol and toothbrush (worked for another post about this model), and listened through the headphone jack (static is the same).
    • revenerd
      • Sep 2022
      • 11
      Attached is a recording of the noise. The pop is when the 'No Signal' text moves on the screen.
      • triplefour
        • May 2014
        • 1747
        interesting problem. never seen this on any tv i worked on but i havent fixed a lot of hisense tvs. somehow the electrical noise maybe from a coil or transformer? from somewhere (psu or mb) is making it into the speakers. Hopefully someone smarter than me can offer you more help!
        Don't fear the repair...
        • revenerd
          • Sep 2022
          • 11
          There is an inductor on the power board I can hear buzzing. It is located to the right of the long cap on the power board and is labeled LEI-302B.
          Could that be the issue?
          • Diah
            • Feb 2013
            • 6355
            Originally posted by revenerd
            There is an inductor on the power board I can hear buzzing. It is located to the right of the long cap on the power board and is labeled LEI-302B.Could that be the issue?
            buzzing at PSU caused when there are load.. the most i found its at ribbon cable between T-CON and panel or LVDS . as yours LVDS are wires.. i would say start to clean pins and check after soldering... also if you have T-CON just disconnect the panel from it and turn on see the sound / buzzing if there any change.
            • revenerd
              • Sep 2022
              • 11
              Buzz is still there after disconnecting TCON. Also attaching TCON board picture.
              • Diah
                • Feb 2013
                • 6355
                then keep remove load and turn on.. for example wifi BT speaker
                BTW yours photo of MB C70 100uf 16V its formed on the top shape or its light shadow
                • revenerd
                  • Sep 2022
                  • 11
                  I disconnected everything I could. I also unscrewed the boards from the panel and placed a rubber mat under them to see if was something coming through the chassis. Even with the speakers disconnected, the sound comes through the headphone jack.
                  I checked the cap C70, it looks ok. No different that the others.
                  • CapLeaker
                    Leaking Member
                    • 8081
                    Poke around with an oscilloscope.
                    • revenerd
                      • Sep 2022
                      • 11
                      Unfortunately, my knowledge, experience, and tools do not go that far.
                      • revenerd
                        • Sep 2022
                        • 11
                        The digital out is clean audio. I also noticed the left side of the screen is slightly darker than the right, it's almost imperceptible. If any of this could be related.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4287
                          • Italy - Milan
                          I think there is something related to the microprocessor, maybe a partial desoldering or a leakage between pins (dirt?) of it or the amplifier chip.. take a proper bay, sorry i don't remember the name, put the main board inside and fill it with alcool and let it stay for many minutes, then wash it and dry it, or another way let it boil a few seconds with distilled water or water + vinegar
                          • alfatv
                            • Sep 2020
                            • 353
                            Those electrolytic caps on main board are likely to fail. Could be some other causes. Even with a scope it could be tough to troubleshoot.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4287
                              • Italy - Milan
                              is there a silicon pad on the cpu?
                              • revenerd
                                • Sep 2022
                                • 11
                                Yes, there is a pad on the underside of the CPU heatsink.
                                I removed the soldered on metal cage around the CPU chip and removed the heatsink. I cleaned around the CPU with alcohol and a toothbrush, saturating the area well. I allowed it to dry then reconnected. The hum and click was still present but drastically reduced. I connected a video source and when audio was playing, the noise was imperceptible. I reassembled everything.
                                After reassembly, I conned a source and started playing video. It was normal, however, after a few minutes of playback, the buzz returned. It is there, distraxtively, through all of the audio.
                                Also, on a white screen, the left half of the screen is slightly darker. It's not noticeable during normal playback.
                                I've attached a picture of the CPU.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4287
                                  • Italy - Milan
                                  Are you able to reflow the cpu with soldering iron stick?
                                  • revenerd
                                    • Sep 2022
                                    • 11
                                    I've never tried that on pins that small and close together. Is it just running the tip across them to heat them up?
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4287
                                      • Italy - Milan
                                      apply much flux, use a salami flat round tip, or a common conical 1mm tip, ad a bit of solder tin, run over the pins slowly, but there are plenty YouTube videos about..
                                      • jmandawg
                                        Hisense F42K20E static out of speakers even with sound turned down
                                        by jmandawg
                                        I found a Hisense F42K20E in the trash. The picture works great, but there's static coming out of both speakers even with sound turned down to zero.
                                        I'm attaching some pics. I'm not sure what happend to the main power board, it looks like crap....
                                        08-18-2020, 03:50 PM
                                      • ShahZaib Ghumman
                                        Can I Swap Screens Between Two Hisense 75” QLED TVs?
                                        by ShahZaib Ghumman
                                        Hey folks,
                                        I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                                        A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                                        So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                                        03-25-2025, 10:59 PM
                                      • nono34
                                        Hisense stuck in Colors cycle like test pattern.
                                        by nono34
                                        I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                                        I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                                        10-24-2024, 04:31 PM
                                      • DoubleBogey817
                                        HISENSE 65H6510G (13 AUG 2020) - POWER ISSUES
                                        by DoubleBogey817
                                        HISENSE 65H6510G (13 AUGUST 2020)
                                        When powered on, initial splash screen (HISENSE ANDROID TV) displays for a few seconds then power shuts off. Tried updating firmware with USB flash drive (can't find 4GB drive but did format larger drive in FAT32) with no luck. Flash drive would be accessed but would never get to the update process. I have ordered a board (RSAG7.820.7911/ROH, PART# 242585) from eBay which will arrive in a few days. Does anyone have any input of whether I am chasing down the right trail or should I be trying something else? I appreciate your time and wish to say thank...
                                        02-16-2024, 10:58 PM
                                      • Track4207
                                        Hisense H50N5300UK reboots when showing full red images
                                        by Track4207
                                        Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
                                        What happens:
                                        • TV appears to operate normally, for an indefinite amount of time until a problem image appears
                                        • The problem image is displayed very briefly, then the
                                        08-30-2023, 11:58 AM
