Hi guys, I want to try revive a motherboard for a hisense 55 that only lights up the motherboard. does any one have the emmc files ? any help is appreciated. i have seen the emmc pinout on kenotrontv https://kenotrontv.ru/files/file/746...ag78207918roh/
Hisense A6100 Files Request
by EazyBoneI am extremely new to programming and dipping into this. I picked up a XGECU T48 Programmer and have the correct socket for EMMC.
I took the EMMC off a working main board with no problems and threw it into the programmer. I click analysis IC and it gives me a report (attached) of the current EMMC. Model H26M41204HPR
1) I manually found this chip(above model number) in the select IC section of the XGPRO 12.xx programmer software and it had a option for 4 bit and 1 bit. I chose 4... is this correct?
2) In the options section point number 2 operation says "30...5 Photos -
by AlexVGHi,
I came across with
SAMSUNG UE65HU8500
ONE CONNECT BN41-02135
Chassis GOLF_UHD_1MP_JACK
TV can not recognise ONE CONNECT box, so I need to know the pinout of the CN 3301 connector.
Moreover, on the main is written A5V. However, cable connected this pin to the GND.
Maybe somebody have an experience with the same issues?
I need your help.
Thank you.... -
by CornholioGSMHello all,
help needed.
I want to made backup of boot and all partitions from emmc desoldered from old phone.
So i have wired emmc directly to RT809h - Dat0, GND,CMD, CLK, VCC, VCCQ - on programmer sw set Smart Identify to EMMC ISP and voltage to 3.3V.
In Settings (N) i have set area to user, boot1,boot2 and EXT and vccq set to 1.8V (tested 3.3V too).
Problem is, that i still get Read Timeout Error
OK - emmc can be dead...so i have tested emmc wires connection to micro SD adapter and then in card reader and emmc was detected.
So...01-16-2025, 04:34 PM -
Hello
Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v... -
by saud52Dear colleagues!
I need eMMC firmware and eMMC pinout
for LED TV Samsung UE46H7080SV
chassis: U89A
motherboard: BN41-02167A
panel: CY-SH046DSLV1H
eMMC: KLM4G1FEAC
thanks in advance...12-18-2021, 01:58 AM - Loading...
