Hisense H58AE6100UK - discolouration and slow load on right side of display
  • djmka
    • Aug 2021
    • 35
    • England
    Hello.
    I have a Hisense 58" 4K television which has a strange issue whereby the right half of the screen takes slightly longer to load an image than the left. It also has discolouration and horizontal blocks. I've attached images of the colour problem and blocking but do not know how to attach a video of the lagging. Can anyone please advise me how to upload a video? Many thanks
  • djmka
    • Aug 2021
    • 35
    • England
    Re: Hisense H58AE6100UK - discolouration and slow load on right side of display
    Could this be a faulty TCON? Or could it be a faulty ribbon cable going to the panel?
    • diif
      • Feb 2014
      • 6978
      • England
      Ribbons don't just go faulty. Possibly the tcon or a component on one of the driver boards.
      You need to take the back off for testing/checking.
      • djmka
        • Aug 2021
        • 35
        • England
        Thanks diif. Are you able to tell me what to check on the driver board and how to do it, please?
        • djmka
          • Aug 2021
          • 35
          • England
          One other thing - the ribbons have an arrow on one end. Should it point up or down? Do they have a right and wrong way?
          • diif
            • Feb 2014
            • 6978
            • England
            Post decent photos, an arrow would suggest a direction.
            It's hard to tell what the problem is with the poor source photos.
            • djmka
              • Aug 2021
              • 35
              • England
              Hope these images better show the problems I'm having.
              • Diah
                • Feb 2013
                • 6460
                firmware...
                • djmka
                  • Aug 2021
                  • 35
                  • England
                  Would firmware affect only one side of a TCon?
                  • Diah
                    • Feb 2013
                    • 6460
                    any Issue at MFC driver section lead the screen refresh / discharge fault.
                    • djmka
                      • Aug 2021
                      • 35
                      • England
                      So do you suggest buying a replacement TCON?
                      • Diah
                        • Feb 2013
                        • 6460
                        start with log in service menu clear chip (hard reset ) if didn't help try downgrade firmware.. or search hisense france if they have issued this fault with flashing only mfc.bin driver
                        • djmka
                          • Aug 2021
                          • 35
                          • England
                          Thanks Diah. Would you know how I can get into the Service Menu by any chance? I guess there's some magic key sequence on the remote control that I need to press.
                          • Diah
                            • Feb 2013
                            • 6460
                            open the normal Menu and go to Sound ---- Advanced Audio Settings .. Scroll down and highlight the Balance slider, make sure it is on 0 -- Enter 1969 on your remote -- green "M" will appear at the top left.. hit menu to open service menu.
                            • djmka
                              • Aug 2021
                              • 35
                              • England
                              Thank you. I managed to access the Service menu but could not find the “Clean chip” option. I have attached a picture of the menu. Please advise. Thanks.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4498
                                • Italy - Milan
                                djmka unfortunately you are wasting time with these procedures , the fault is clearly the panel, exactly the gate drivers (side cofs), there is a very huge duscussion with me and another user called Ancient1, started last december, i don't think you have to annoy yourself with all the reading, i tell you it ended removing the side cofs of one side , so the first step to do is to disconnect one ribbon tcon>panel at a time and see which side is the worst visualizing..
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  thread link davi.p recomeneds reading
                                  https://www.badcaps.net/forum/showth...light=Ancient1
                                  • Diah
                                    • Feb 2013
                                    • 6460
                                    look under all you will find clear chip start with option.
                                    and who want to be clever here.... don't advice on time ...to waste... this issue i have it on hisense and here the threat.
                                    • djmka
                                      • Aug 2021
                                      • 35
                                      • England
                                      Update -
                                      I have removed the bezel to expose the 6 side cofs. At least two of them looks to be damaged (probably happened whist removing the bezel a month or so ago to fit new backlights).
                                      If I move the first one the colours go back to normal. The same happens when I move the other, more damaged one.
                                      Are you (Davi.p) saying that removing the damaged cofs will (may) fix the issue? If so, do I cut them as close to the panel as possible or should I leave a certain amount?
                                        • 12306
                                        • U.S.
                                        yes those are toast, remove all on THAT SIDE ONLY, slowly peel it away from the glass, if you go slowly it should all come off pretty easily, bound to be some videos on youtube that you can check if you like.
                                        • djmka
                                          Hisense H55U7BUK - slow to load image
                                          by djmka
                                          I have a Hisense 55" H55U7BUK television which has a very strange issue. When you first turn it on the the Hisense logo page appears as expected, then an image appears with the top 25% of the screen displaying correctly and the remaining 75% as if the T-Con is faulty (i.e. it has vertical lines). The screen then starts to recover the missing 75% line by line, taking a minute or so, until you end up with a great picture (please see attached photos). FYI - I've tried replacing the T-Con board but get the same results.
                                          Has anyone seen this type of issue before?...
                                          12-17-2021, 04:01 PM
                                        • AJ847.63e
                                          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                          by AJ847.63e
                                          Hi Folks,
                                          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                          05-06-2025, 10:37 PM
                                        • frannyjunk
                                          Hisense H8G not turning on, only slow blinking white LED
                                          by frannyjunk
                                          These Hisense H8G series (or Q8G if you are in Canada) tv appears to have a common failure of the main board. Many posts on Reddit without a solution. Mine is a 55" tv hence the 55H8G model (TV comes in 50, 55, 65 and 75". Corresponding models are 50H8G, 55H8G, 65H8G and 75H8G). Symptom is that the tv will not turn on, only a slow blinking white LED near the on button on the tv. Has anyone found a repair for the main board? I can buy a replacement main board, but would prefer to repair my main board. Thanks.
                                          05-17-2023, 10:31 AM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 10:56 AM
