Small RCA TV white screen
  • BustinCaps
    • Mar 2016
    • 43
    Re: Small RCA TV white screen
    Originally posted by R_J
    Digikey has the AO3420 which is a 6 amp version that should be ok. They also have a RUR040N02TL 4 amp version.
    Thanks. Someone else also suggested this.
    • BustinCaps
      • Mar 2016
      • 43
      I believe RUR040N02TL 4 amp version is the one I have in the TV right now. The one's that are marked XF. Attached is what I bought from DigiKey.
      • R_J
        • 9627
        That will work, You should have mentioned you got the mosfet from Digikey earlier as there is also a 100ma transistor with the marking XF, which would not work.
        So good to here you have it repaired. The red/green line is the R.F. channel indicator
        • BustinCaps
          • Mar 2016
          • 43
          Yes it is working. Thanks for your help. Much appreciated. It appears the whole problem was the wrong resistors. I was hoping you could explain how the transformer works. Is it upscaling or downscaling the power and is it converting DC to DC or DC to AC? I want to learn what was going on there.
          • dskall
            • Oct 2016
            • 2905
            • usa
            In your case power supply is 12v. So to run backlight's and such the transformer is boosting voltage.
            I'm confused. Resistors where bad? You then replaced with wrong value. Then put old ones back in, or new ones of correct value?
              • 12332
              • U.S.
              #26
              wondering the same, I think he had a bad mosfet too.
              • R_J
                • 9627
                Transformers only work with AC they do not pass or convert DC (the diodes then convert the ac to dc)
                The mosfet you replaced switches the raw 12volt input across the pimary of the transformer at about 50khz, this induces a current in the secondary windings of the transformer, there are likely 3 or more secondary supplies in this unit, one of them is a negative voltage whose diode is likely D303 and C323 is the filter cap.
                D306, D305, D302, likely supply other voltages for the tv.
                I suspect the mosfet shorted and you replaced it with a proper replacement, BUT you also replaced the source resistors at the same time. the values you used for those resistors were too high a value (2 10Ω in parallel=5Ω) The controller monitors the voltage drop across these resistors and was likely sensing a fault and shutting down. When you reinstalled the correct resistors (2 1.5Ω in parallel= 0.75Ω) the circuit operated as it should.
                The inverter circuit for the ccfl uses a different transformer (T401) and drive circuit
                • BustinCaps
                  • Mar 2016
                  • 43
                  So I replaced mosfet and resistors at the same time. I thought both were bad. Only the mosfet was bad and the old resistors (1 ohm) where good. The new resistors I used were 10 ohms so that was the problem.
                  I think there is a separate transformer that runs the backlight power to the lcd screen.
                  • BustinCaps
                    • Mar 2016
                    • 43
                    That's exactly what happened. Forgive my lack of knowledge on electrical circuits but is the mosfet creating the ac by switching at 50khz? Is the mosfet creating the ac from the 12v input?
                    • harp
                      White screen repairs
                      by harp
                      To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                      Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                      On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                      05-13-2024, 03:43 AM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • EazyBone
                      Sharp LC-65Q620U White Screen
                      by EazyBone
                      Another TV topic!!
                      I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                      The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                      Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                      08-21-2024, 12:56 PM
                    • hcinne
                      Dell G15 ryzen edition black screen 2 amber 1 white
                      by hcinne
                      I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                      07-23-2024, 07:56 AM
                    • Chrissygizmo
                      Panasonic TX-48CX350B backlights but white screen , blank screen
                      by Chrissygizmo
                      Hi all, I’ve got a problem I hope someone can help me fixi.
                      I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                      01-11-2025, 03:18 PM
