I am trying to fix a small RCA TV for a friend. It holds sentimental value for his father. Initially it had what looked like some burned out resistors and would not turn on. I changed out the resistors and now it turns on but I only get a white screen. I have no experience fixing TVs but hope someone can point me in the right direction on what to check or how to proceed. Thanks. Attached are some pictures.
					Small RCA TV white screen
	Tags: None
 Re: Small RCA TV white screen
 Could be a bad capacitor/s the electrolytic caps are usually the ones that go first, can be bad and not be bulging.Comment
 and check all the solder joints: https://www.google.com/search?q=bad+...ih=607&dpr=1.5Comment
 The plug in picture four looks crooked, make sure it is seated properly. (the flat cable does not just pull out and get pushed back in, the latch must be released) What resistors did you replace that made it turn on, Resistors don't usually burn unless something else is bad.
 I guess the redit bot couldn't help 3 months agoLast edited by R_J; 06-29-2022, 03:51 PM.Comment
 Yeah the cable has a brown latch that slides out then you slip the cable in and slide it back in to lock it. The connection should be good. The resistors are the ones in picture 4 right below transistor. The thing is I replaced the top transistor too but maybe it was the wrong one. The markings on the original transistor were 339 d. The transistor I replaced it with is a N channel. Maybe it should be a P channel?The plug in picture four looks crooked, make sure it is seated properly. (the flat cable does not just pull out and get pushed back in, the latch must be released) What resistors did you replace that made it turn on, Resistors don't usually burn unless something else is bad.
 I guess the redit bot couldn't help 3 months agoComment
 If it was a sot23-3 marked 339, (in picture 5) it was a FDN339AN N-Channel mosfet. How did you find the correct values of the resistors, if they were burnt? What values did you use? They seem to be the mosfet source resistors, and are likely around 1Ω.
 If the mosfet was bad, the drive ic301 may also have been damaged.
 This is a SMPS, IC301 is the drive ic for Q305 mosfet that drives the transformer T301. I would check for shorted diodes on T301 secondary like D302, D303, D305, D306 etc.
 You are likely missing all the voltages created by this smps circuitLast edited by R_J; 06-29-2022, 08:46 PM.Comment
 I wasn't sure about the resistors so I got some 10 ohms resistors (10R0). When I check the old resistors that I removed, they are 1.5 ohms.
 IC301 appears to be 3843B pwm controller (see attached image). The below values are what I see for the pins 1-8 on IC:
 1. 6.7v
 2. 1.6v
 3. .15v
 4. 2.3v
 5. 0 v
 6. 1.3v
 7. 12.2v
 8. 5v
 T301 shows 12.5v going in on the primary at two inputs but zero or -.02v and -.03 v coming out on the secondary. Could transformer be bad?
 Also, capacitor C323 shows negative voltage on the ground side of -12v and nothing on the positive side. Strange??
 Any ideas? Thanks.Comment
 Why suspect the transformer? the transistor you installed is wrong, the source resistors should be 1.5Ω not 10Ω and circuit is not going to work with wrong parts installed, and could cause even more damage. I suspect there was nothing wrong with that circuit and there was likely a fault in the secondary causing this smps to be loaded down.
 C323 is the filter capacitor on a negative supply, that is why the positive is connected to ground. It might be possible the smps circuit is trying to work.
 Where are you checking the secondary voltages that you get "zero or -.02v and -.03 v coming out on the secondary"
 To work on these circuits properly you need a scope to see if the ic is working and generating pulses.Last edited by R_J; 06-30-2022, 06:56 PM.Comment
 Your controller chip is probably ok. The resistors you replaced are probably current sense and are a different problem. If you ohmed the originals and they were 1.5 ohms then I would put them back in. And you will need to read secondary voltages after the diode. Not at output of transformer. You may be able to check controller output if your meter reads frequencies up to 5kLast edited by dskall; 06-30-2022, 08:14 PM.I assume no responsibility for any stupid suggestions I might post.Comment
 So I put back the old mosfet transistor and resistors. Turned it on and immediately got the magic smoke from the transistor. That transistor is toast. I then put back the XF transistor and get the below grainy pictures. There is a red or green line that appears vertically when I switch from VHF to UHF. I'm guessing I need FDN339AN mosfet for it to work properly. This mosfet looks like it's going to be hard to find. It's out of stock at most places.
 looks like this one will work: https://www.digikey.com/en/products/...AO3420/1855956Comment
 Thanks. I'll check it out.looks like this one will work: https://www.digikey.com/en/products/...AO3420/1855956Comment
			by harpTo ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
 Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
 On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
			by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
			by EazyBoneAnother TV topic!!
 I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
 The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
 Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
			by hcinneHello,
 I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
			by ChrissygizmoHi all, I’ve got a problem I hope someone can help me fixi.
 I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...01-11-2025, 03:18 PM
- Loading...
