Small RCA TV white screen
Re: Small RCA TV white screen
I believe RUR040N02TL 4 amp version is the one I have in the TV right now. The one's that are marked XF. Attached is what I bought from DigiKey.
That will work, You should have mentioned you got the mosfet from Digikey earlier as there is also a 100ma transistor with the marking XF, which would not work.
So good to here you have it repaired. The red/green line is the R.F. channel indicatorAttached FilesLast edited by R_J; 07-01-2022, 08:49 PM.Comment
Yes it is working. Thanks for your help. Much appreciated. It appears the whole problem was the wrong resistors. I was hoping you could explain how the transformer works. Is it upscaling or downscaling the power and is it converting DC to DC or DC to AC? I want to learn what was going on there.Comment
In your case power supply is 12v. So to run backlight's and such the transformer is boosting voltage.
I'm confused. Resistors where bad? You then replaced with wrong value. Then put old ones back in, or new ones of correct value?Last edited by dskall; 07-02-2022, 11:20 AM.I assume no responsibility for any stupid suggestions I might post.Comment
Transformers only work with AC they do not pass or convert DC (the diodes then convert the ac to dc)Yes it is working. Thanks for your help. Much appreciated. It appears the whole problem was the wrong resistors. I was hoping you could explain how the transformer works. Is it upscaling or downscaling the power and is it converting DC to DC or DC to AC? I want to learn what was going on there.
The mosfet you replaced switches the raw 12volt input across the pimary of the transformer at about 50khz, this induces a current in the secondary windings of the transformer, there are likely 3 or more secondary supplies in this unit, one of them is a negative voltage whose diode is likely D303 and C323 is the filter cap.
D306, D305, D302, likely supply other voltages for the tv.
I suspect the mosfet shorted and you replaced it with a proper replacement, BUT you also replaced the source resistors at the same time. the values you used for those resistors were too high a value (2 10Ω in parallel=5Ω) The controller monitors the voltage drop across these resistors and was likely sensing a fault and shutting down. When you reinstalled the correct resistors (2 1.5Ω in parallel= 0.75Ω) the circuit operated as it should.
The inverter circuit for the ccfl uses a different transformer (T401) and drive circuitLast edited by R_J; 07-02-2022, 01:21 PM.Comment
So I replaced mosfet and resistors at the same time. I thought both were bad. Only the mosfet was bad and the old resistors (1 ohm) where good. The new resistors I used were 10 ohms so that was the problem.
I think there is a separate transformer that runs the backlight power to the lcd screen.Comment
That's exactly what happened. Forgive my lack of knowledge on electrical circuits but is the mosfet creating the ac by switching at 50khz? Is the mosfet creating the ac from the 12v input?Transformers only work with AC they do not pass or convert DC (the diodes then convert the ac to dc)
The inverter circuit for the ccfl uses a different transformer (T401) and drive circuitComment
by harpTo ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment... -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by EazyBoneAnother TV topic!!
I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?... -
by hcinneHello,
I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the... -
by ChrissygizmoHi all, I’ve got a problem I hope someone can help me fixi.
I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...01-11-2025, 03:18 PM - Loading...
