Soyo VT17N71
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Soyo VT17N71
    PS. AFAIK, voltage regulators have a designation of I or IC. Transistors which can look like voltage regulators are marked with Q.
    Again, read the markings on the chip, look up its datasheet and you will get all the info.
    --- begin sig file ---
    --- end sig file ---
    • PlainBill
      • Feb 2009
      • 7034
      Re: Soyo VT17N71
      One more - An IC often has a designation of U
      PlainBill
      • bsweasel
        • Jun 2010
        • 82
        Re: Soyo VT17N71
        See yellow circled items. There may be more, but your pic isn't top down. It is slanted and hard to see.
        Ok, then for example:
        So the small one is this:http://www.fairchildsemi.com/ds/FQ/FQD13N06L.pdf
        so if interpret your message right, your telling me I should read 60v with the unit powered on? if not I should replace?
        • retiredcaps
          • Apr 2010
          • 9271
          Re: Soyo VT17N71
          Yes, that is correct. However, you may want to double check the part number you are looking up.
          I'm not familar with this TV, but 60V DC sounds like a lot? The ones I'm used to seeing on LCD computer monitors is 2.5V, 3.3V or 5VDC.
          The only "TV" I have worked on is the Daytek and all the voltage regulators are in the 2.5V, 3.3V, and 5VDC range. So again, double check your part number.
          More experienced members should be able to tell you if 60V DC is normal on this board.
          • bsweasel
            • Jun 2010
            • 82
            Re: Soyo VT17N71
            Its actually a computer monitor...I somehow stupidly posted it in the wrong forum.....I've double checked, its for sure FQD13N06L.
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              Re: Soyo VT17N71
              I have zero experience in board design/layout, but I find it strange that this monitor has an external power supply outputting 12V DC uses a 60V voltage regulator? Especially on the logic board?
              I have 2 LCD monitors (in stages of repair) that use external power supplies and I don't recall seeing any DC volts higher than the what is being output by the external power supply.
              Maybe one of the more experienced people can explain from a design theory point of view why such a higher voltage is needed?
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Re: Soyo VT17N71
                uhm... 60V is what the mosfet he posted a link to (in post #23) is rated for.
                not a v-reg..
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  Re: Soyo VT17N71
                  WOW, Clearly, time for a beverage! And new glasses!
                  And I just saw toasty in another thread talking about how to test mosfets!
                  Heading to the fridge now ....
                  not a v-reg..
                  • bsweasel
                    • Jun 2010
                    • 82
                    Re: Soyo VT17N71
                    I found the Vreg. its and AIC1084PM datasheet looks to rate it at a max of 3.3v, with power to it, with inverter disconnected it measures 8 volt with 1 probe on (pin 1) ground and the other on Vin (pin 3) and 1.25v on stub (pin 2). Now if I move my ground prob to the PCB ground (screw hole) Pin3 reads 10.x volts, pin2 reads 3.3volts. So why is one ground point reading differently than the other? Now off to read how to test that mosfet that gets HOT when it has the load of the inverter connected to it.
                    • bsweasel
                      • Jun 2010
                      • 82
                      Re: Soyo VT17N71
                      When tested with the diode setting on my meter appears to be conducting accross all 3 terminals no matter what...out of circuit....btw. And gets very hot in circuit under load....can I assume its crap and I need to find a replacement???
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Re: Soyo VT17N71
                        Yes.
                        PlainBill
                        • bsweasel
                          • Jun 2010
                          • 82
                          Re: Soyo VT17N71
                          Ok, so I took the MOSFET from the other board since I have 2 of these things.... It at least wasn't open or shorted. I got a .191 reading from it using the diode test on my meter. So I solder it in place. Power up the monitor and the Power LED is lit with both green and orange. The board does not appear to be heating up as before. But I don't get any picture and the back lights don't light up. This is getting frustrating. It appears to be a never ending trail of bad components on this thing.
                          PS. Could not find a source for replacement on this MOSFET. Anyone have a good cross reference source for it? After I figure out one of these I'll be wanting to repair its donor/twin and will need a new MOSFET for sure.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            Re: Soyo VT17N71
                            PS. Inverter boards have fuses just after input and both fuses on both inverters are fine
                            Please post a picture of the clear focused picture of the inverter board (top down view, both sides). We only have the logic board pics.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #34
                              Re: Soyo VT17N71
                              Do you have a source plugged into the monitor?
                              Does the LED go green first and then orange? If yes, how long does it stay green before going orange? Once it goes orange, does it stay orange?
                              Can you see a picture if you shine a flashlight on it?
                              • bsweasel
                                • Jun 2010
                                • 82
                                Re: Soyo VT17N71
                                Both green and orange light up at the same time. With or without a source. I don't see any picture with a light shining on it. Also the power button does not appear to do anything. LED lights when it comes on and stays on till I unplug it...
                                • bsweasel
                                  • Jun 2010
                                  • 82
                                  Re: Soyo VT17N71
                                  http://www.simonlo.com.tw/download/s...0QDI17_noC.pdf
                                  This PDF shows a schematic and has crazy detail that is way out of my league.
                                  Inverter pictures attached.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    Re: Soyo VT17N71
                                    Any chance you found schematics of the logic board?
                                    • bsweasel
                                      • Jun 2010
                                      • 82
                                      Re: Soyo VT17N71
                                      I looked....google apparently does not know all!!
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        Re: Soyo VT17N71
                                        Sorry, I'm confused with the green and orange light up at the same time statement. Are you saying that the power LED (one LED) is green and orange?
                                        Or are there two LEDs and one is green and one is orange? If there are two LEDS, what are they?
                                        In fact, post a picture of the LED that is on.
                                        • bsweasel
                                          • Jun 2010
                                          • 82
                                          Re: Soyo VT17N71
                                          Its a dual color LED. one LED that lights both green and orange. I'm guessing its green when power is on, and orange in sleep mode.
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
                                          • MrzPdlch
                                            Blown fuses on Gigabyte GTX 980TI 6GB
                                            by MrzPdlch
                                            Hey everyone,
                                            I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                                            Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                                            Find some pictures of the actual GPU together with a picture of how it should look like.
                                            I also wonder whther it might be a problem that there...
                                            03-10-2024, 04:14 PM
                                          • BMCappelletti
                                            Sonos Play 1 with blown cap and fuses
                                            by BMCappelletti
                                            Hi there.
                                            I was given a Sonos Play 1 (yeah, very old) that does not turn on.
                                            Checking the main board, I can see a blown cap, that connects to two blown fuses. Right by the LAN port.
                                            Where should I start looking for the main fault?
                                            Thank you....
                                            08-10-2023, 04:02 PM
                                          • gozotto
                                            Sharp LC-40LE812E fuses blown
                                            by gozotto
                                            I repaired a Sharp LC-40LE812E TV with the main power board DPS-126CP B.
                                            All fuses blown and the capacitor C7813 (220pF 1KV) was cracked. After replacing both, the TV works again without any problems. After 2 weeks the same problem apears with the same symptoms. What can the C7813 blown again and again? The schematic can be found here.
                                            Thanks in Advance
                                            gozotto
                                            04-04-2022, 12:14 PM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
