Sharp LC-40LE812E fuses blown
  • gozotto
    • Aug 2018
    I repaired a Sharp LC-40LE812E TV with the main power board DPS-126CP B.
    All fuses blown and the capacitor C7813 (220pF 1KV) was cracked. After replacing both, the TV works again without any problems. After 2 weeks the same problem apears with the same symptoms. What can the C7813 blown again and again? The schematic can be found here.
    Thanks in Advance
    gozotto
  • Diah
    • Feb 2013
    • 6376
    Re: Sharp LC-40LE812E fuses blown
    with out looking to the manual-- if yours repair was on the primary section at PCB. then need complete circuit parts to replace at once..( Netzteil Set )
    • gozotto
      • Aug 2018
      Did you mean the rectifier and the filter caps? I checked both and the filter caps have a low ESR.
      • Diah
        • Feb 2013
        • 6376
        not rectifier .. upload clear photo to see C7813 in circuit
        • dskall
          • Oct 2016
          • 2905
          • usa
          I would replace it with a 2k and check all components in pfc circuit. Also check voltage at cap.
          • gozotto
            • Aug 2018
            I replaced the C7813 with a 3kV one and now I hear some noise from board (transformer). Imeasured the voltage on the caps C7800A/B => 328V. I desolderd the MOSFET and checked it outside with the component tester. All good.
            The C7813 can only blown with a voltage to high? But why?
            • dskall
              • Oct 2016
              • 2905
              • usa
              328v in standby? What is it when powered on?
                Surface Mount Fuses Fundamentals Datasheet
                TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                10-07-2024, 06:07 AM
              • MrzPdlch
                Blown fuses on Gigabyte GTX 980TI 6GB
                by MrzPdlch
                Hey everyone,
                I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                Find some pictures of the actual GPU together with a picture of how it should look like.
                I also wonder whther it might be a problem that there...
                03-10-2024, 04:14 PM
              • BMCappelletti
                Sonos Play 1 with blown cap and fuses
                by BMCappelletti
                Hi there.
                I was given a Sonos Play 1 (yeah, very old) that does not turn on.
                Checking the main board, I can see a blown cap, that connects to two blown fuses. Right by the LAN port.
                Where should I start looking for the main fault?
                Thank you....
                08-10-2023, 04:02 PM
                Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                12-14-2023, 07:45 PM
              • cmlewis89
                LG 47LB5DF blown power supply board
                by cmlewis89
                Hi folks,
                I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                09-03-2024, 07:50 PM
