LG TV 49LW5700 does not power no Standby Voltage(PSU EAX62865401)
  • R_J
    • Jun 2012
    • 9625
    Re: LG TV 49LW5700 does not power no Standby Voltage(PSU EAX62865401)
    Originally posted by mohsinrizwan
    any possibility I bypass standby and give 3.5V externally?
    All this would do is supply 3.5v to the main board, the power supply will never operate without the standby circuit working first. The standby circuit also supplies vcc to the other ic's on the power supply.
    • dskall
      • Oct 2016
      • 2905
      • usa
      You have a schematic that have the voltages. Just go around that IC and check for wrong voltage.
      • GMAN6325
        Gman6325
        • Mar 2023
        • 16
        Does anyone happen to have the schematic for this power supply board? It's an EAX62865401. Thanks
        • lotas
          • Jan 2016
          • 4900
          • Russia
          Look, it's not her.
          • GMAN6325
            Gman6325
            • Mar 2023
            • 16
            Thanks. I'm trying to figure out why the relay isn't getting voltage to kick on. I'm not getting my 3.5v stby so I have to figure this out first. It's just alot easier with the schematic. Thanks again
            • GMAN6325
              Gman6325
              • Mar 2023
              • 16
              Ok so it looks like my board is ok. Looks like it's gonna be the backlights. Will check for correct voltages first going to backlights.
              • GMAN6325
                Gman6325
                • Mar 2023
                • 16
                Well it might be the mainboard. I only have 36v on the LED+ Pins on p202. Nothing on the others. 36v is low. What should I have here for the LED's?? If I have nothing on the DRV ON pin, would it be something on the main board?
                • R_J
                  • Jun 2012
                  • 9625
                  If the backlights were working you would have 53 volts on P202 LED+, but if the backlights are bad (very likely) the backlight driver circuit will go into protection and you will only have the base 36volts on LED+
                  What is the voltage on P201 EROOR (that's how it is spelt) pin? If there is a backlight error ic801 will likely tell the main board to turn off the DRV_ON signal.
                  Monitor the DRV_ON pin when the tv is first turned ON and see if this pin is 3volts before going to 0
                  • GMAN6325
                    Gman6325
                    • Mar 2023
                    • 16
                    I will check this when I get off this afternoon. I guess I need to check the backlights first with backlight tester to see if they even come on. I forgot to do this. I will let you know what I find. Im hoping it is the backlights and not the mainboard. Thanks for the reply.
                    • GMAN6325
                      Gman6325
                      • Mar 2023
                      • 16
                      Ok so I don't get much on that DRV_ON pin. In stby I have nothing (5mV). When I press power on it only jumps up to 39mV. So main board must not be sending the drive signal. I did test backlights with a tester and I can get them to light up. What's crazy is I tried the jump method with resistor and main board unplugged and I can't them to light. They light with a led tester but not when stby pin is jumped to Drv_on pin. Unless I'm using wrong value resistor. I read 2 different values. Someone said 200 ohm to 500 ohm. Another person said 10k.
                      • R_J
                        • Jun 2012
                        • 9625
                        Backlight testers are not reliable, they only supply about 30ma of current. I don't know how many times I here that the backlights must be ok because the tester light them up. One bad led that fails when the string draws about 130ma and the supply shuts down.
                        • GMAN6325
                          Gman6325
                          • Mar 2023
                          • 16
                          Good to know. Do you think I should remove front and check the LED strips individually?
                          • GMAN6325
                            Gman6325
                            • Mar 2023
                            • 16
                            I forgot to mention the Eroor voltages. 0v when in stby and 2.1mV when powered on.
                            • nomoresonys
                              • 12332
                              • U.S.
                              #34
                              Don't worry about 2.1 millivolts it's basically the same as 0 volts.
                              • GMAN6325
                                Gman6325
                                • Mar 2023
                                • 16
                                So I redid the jumper test with main board unplugged and my backlights came on. So now I know it's the mainboard. From what I'm reading, it really can't be fixed other than the baking/reflow. Any other suggestions?
                                • nomoresonys
                                  • 12332
                                  • U.S.
                                  #36
                                  I think so, can try a diy reflow of the bga chip, really not much to lose, there's a ton of videos about it on youtube, some are better than others of course.
                                  • nomoresonys
                                    • 12332
                                    • U.S.
                                    #37
                                    Here's an interesting method, some use a little no-clean flux on 3 sides of the chip and try to let it flow under the chip: https://www.youtube.com/watch?v=ZDQNOU2w_ek
                                    • nomoresonys
                                      • 12332
                                      • U.S.
                                      #38
                                      A temp probe would be very handy so you can tell what's going on, otherwise it's just guesswork, then you just get the temp up to melt the solder then slowly back off the heat to try to avoid thermal shock, I think whats cool about the light bulb over heatgun is you won't be getting thermal shock on the heat up because it will be slower than blasting with a heatgun, specially one that might not be tayloered for the job, just one temp probe there, prolly many others on there too: https://www.ebay.com/itm/29390306772...Bk9SR9KZyJTaYQ
                                      • nomoresonys
                                        • 12332
                                        • U.S.
                                        #39
                                        Here's Bob with a diy station, not everyone will want to make this but notice his profile, on this particular one, notice he goes to 200, solder starts to melt, he then goes up to 225 before backing off, didn't notice what kind of solder was used on that job, so just look up what solder was used on the chip, was probably the usual lead free crap they use, so prolly around 220c to start melting then maybe go to 240 or so then back off, with eithr method: https://www.youtube.com/watch?v=4Hl7-xPg2Sg
                                        • GMAN6325
                                          Gman6325
                                          • Mar 2023
                                          • 16
                                          Well I have the TV up and running. I decided to do the reflow because the tv is old and not even worth paying $100 for a new mainboard. I added flux around bga chip and other chips. I slowly heated each chip and gentlty pressed down on chip every so often. After doing this, I re-installed the mainboard and voila. The TV works. Not sure how long it will last but hopefully the solder melted enough and the chip has a better connection. Thanks for all the suggestions.
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            03-31-2024, 02:12 PM
                                          • SkishyIshy
                                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                            by SkishyIshy
                                            Hey All,
                                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                            03-17-2021, 11:44 AM
                                          • AleMonti
                                            LG 55EG910V - no power and no standby light
                                            by AleMonti
                                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                            After checking the basics I did the following:
                                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                            11-04-2024, 05:02 PM
                                          • redbaron1007
                                            Yamaha HTR-3065 No power/No Standby
                                            by redbaron1007
                                            I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
                                            S9 13.7V
                                            Pwr Ry 0V
                                            AC Det 9.1V
                                            Mgnd 0V GND
                                            The two pins on the transformer for the operation...
                                            09-12-2024, 03:04 PM
