i have this nvr need to reset pattern and password any help i buy it used and it is locked
ds-7732ni-k4 hikvision
by Dan20701Hello all just wondering if anyone knows how to do a hard reset on this model, XVR58C-21D-8CH-V1.1 ?
There are videos on youtube for every other model but this one, I do not have the switch on the board or reset jumpers.
https://www.youtube.com/watch?v=Ao7EwIMDx_c
I do have 2 little pads right next to the firmware chip, I have shorted these and powered the system on and waited a wile
with no luck. I will add picture of these 2 pads.
I do have the bin file from the firmware if its any good to anyone maybe able to edit out the pass I am not sure.
Hey there people
While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
This is what I tried, but not in any order.
Google
YouTube
BIOS
Command Prompt (administrator privileges)
On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...-
10-25-2025, 02:22 AM -
by thstuffA) TV initially dead
B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
C) Was able to perform a Reset from Settings menu and completed out of box configuration.
D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical... -
by mmx01Hi,
The machine was/is password locked for BIOS. You can imagine I am writing here because things did not go as planned... I downloaded and edited both main bios and EC rom flash chips with 866II+ programmer using RCUnlocker for EC and BIOS patcher for BIOS. Verification goes ok for all files but now the computer is not even turning on.
When I press power on, white LED goes on but as soon as I release the power button it goes back to sleep. No beeps or other sings of life. Soldering of both chips is verified with continuity test, all is connected okay. Both chips were...-
by odie34I am a hobbyist (not a professional) so please be gentle...
I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,... - Loading...
