HP Z2 G5 Twr BIOS password removal failure
  • mmx01
    • Feb 2022
    • 16
    • Poland
    The machine was/is password locked for BIOS. You can imagine I am writing here because things did not go as planned... I downloaded and edited both main bios and EC rom flash chips with 866II+ programmer using RCUnlocker for EC and BIOS patcher for BIOS. Verification goes ok for all files but now the computer is not even turning on.
    When I press power on, white LED goes on but as soon as I release the power button it goes back to sleep. No beeps or other sings of life. Soldering of both chips is verified with continuity test, all is connected okay. Both chips were removed from the board for reading/programming and they read back okay after desoldering on no boot = chips are fine & working. When machine did not boot I flashed back original files but it did not change anything. It still does not want to power on. I doubt it is a soldering/overheating problem since I used temp controlled hot air station and a good SMD iron (and I am used to PCB rework).
    Product Name
    HP Z2 Tower G5 Workstation
    Serial Number
    CZC1267FKD
    SKU Number
    453L2EP#ABU
    ​Feature Byte
    3X476J6S6b7N7Q7T7U7W7a8HaUaXapaqaubhdUdpdqedfJfPhKhZjhk8.Hy
    First two are original dump files, the other two are edited ones. After flashing original files back the unit still does not want to boot.
    Did I do something obviously wrong with editing? CMOS battery was removed as well as CMOS reset button pressed.
    Br,
    Mario
  • mmx01
    • Feb 2022
    • 16
    • Poland
    Okay, the problem is resolved. For whatever reason the only working combination appeared to be my original bios + bios patcher and a "clean" EC dump from another site. When I flashed "clean" BIOS + "clean" EC from that site, the machine would turn on but show no picture and restart every 30-60 seconds. I got a clean set of files for BIOS and EC not trusting my work and it still would not work.
    It seems only the original patched BIOS + clean EC combined brought it back to life. It first complained about security rom issue, rebooted few more times claiming to updating BIOS and then complained about no SN/other DMI data and required it entered. It booted in MPM unlocked state so programming was not an issue and luckily I got all of that with BCU before all the changes.
    I am still curious if anyone sees anything obviously wrong with the files from my original post. How the unlocked variants appear to experienced eye. When I looked BIOS patcher seemed to change a number individual bits (likely a flag change) and RCUnlocker removed/replaced the BIOS password block from EC rom, at least binary hex comparison suggests something like that.
    Br,
    M.
    • Mekong500
      • Oct 2024
      • 27
      • Poland
      Br,
      M.
      Hello, could you share clean files for BIOS and EC please? I'm about to try to remove password from this model, but I didn't find any other topics. Thanks in advance
      • Cire3PC
        • Jan 2019
        • 13
        That would be helpful...
        • Olegst44
          Acer Aspire 3 A315-22G - NB8607G02-MB (Compal LA-J761P) - BIOS Password Removal / Clean BIOS Needed
          by Olegst44
          I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
          Device Information:
          - Model: Acer Aspire 3 A315-22G
          - Motherboard: NB8607G02-MB (Compal LA-J761P)
          - BIOS Chip: Winbond W25Q64 (8MB)
          - Serial: NXHE7ER00X95002B784S00
          Problem:
          - BIOS is password protected (Supervisor Password)
          - Boot from USB is disabled in BIOS
          - After 3 wrong password attempts, system shows Unlock Key Hint
          - I have RT809H programmer available
          What I need:
          1. Clean BIOS dump (password...
          04-11-2026, 05:36 PM
        • boticario
          Lenovo FT491/FX390 (NM-B891 REV 2.0) – BIOS password removal/clean request
          by boticario
          I have a Lenovo FT491/FX390 (motherboard NM-B891 REV 2.0) with a BIOS password that I can’t bypass. I’ve tried the usual methods (CMOS reset, jumper, etc.), but the password persists.
          What I need:
          • A clean BIOS dump (without password) for this specific model.
          • Or, if possible, help to remove the password from my current BIOS dump.
          What I can provide:
          • A full BIOS dump (W25Q80dv or similar) if someone can guide me on how to extract it safely with an RT809HSE.
          • Any additional info or photos of the board if needed.
          I know the community has tools...
          03-07-2026, 10:40 PM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • rbdealmeida
          Unlock Request: HP Elite Mini 8 G1a (Product B02PXAV) - BIOS Password Removal / Clean ME
          by rbdealmeida
          My name is Ricky and I'm a repair technician/enthusiast. I've been learning a lot from this community and have successfully done some basic BIOS unlocks in the past, but this particular modern HP model is giving me a really hard time!
          I need some help manually removing the BIOS administrator password from this machine.
          I have already tried using the "HP G9 Unlocker V3.0" on my 32MB dump. I successfully bypassed the U68 Sure Start chip (SPI NAND) by isolating Pin 8, preventing the auto-recovery. The machine boots and bypasses Sure Start,...
          03-24-2026, 01:45 PM
        • Dudebroman
          Lenovo Ideapad Slim 3 Bios Password Ghost
          by Dudebroman
          Hello Hello,
          I have been browsing the site and gotten so much useful info from here, including extremely helpful boardviews and several other very useful types of information. I am very grateful to this community, as I have actually eeked out a living from buying salvage PC's & Macbooks and repairing them. So, thank you all in advance!
          I have searched and found some useful information regarding my issue, but my case is a bit different than the info I'm finding. But if anyone here can give me any useful advice, it would be highly appreciated.
          12-18-2025, 12:22 PM
