TCL 55S421 powers on + LCD display + sound but no backlight
  • howardc64
    • Jun 2017
    • 632
    Likely backlight strip but thought I check before tearing into this panel (read maybe easy to crack along the top edge due to glue so unclip the glued on bracket rather than separating glue... I'll definitely becareful!!! haha)
    Flash light shows image on LCD display
    Have sound (there is notification sound when powering off)
    PSU P401 connector BL_ON 0v -> 3.3v when powering on
    PSU P601 connector (4 wires to 2 LED strips, Each strip = 2 segments with 8+7 6V LEDs). When powering TV from off to on
    Pin 2 0v -> 0v
    Pin 4 85v -> 120v and gradually settle to 85v
    Pin 7 0v -> 0v
    Pin 9 85v -> 116v and gradually settles to 85v
    Pin 4 and 9 mostly holds at 85v while TV powered off after being powered on. If AC plug is removed, these will slowly drain down.
    Does this suggest LEDs are good or bad?
    Don't have LED strip tester but thinking about buying one. I should be able to connect tester on P601 pin 2+4 and pin 7+9 and see either strip light up if good right?
    • 12206
    • U.S.
    Re: TCL 55S421 powers on + LCD display + sound but no backlight
    do you get a backlight flash when you power up?
      • 12206
      • U.S.
      check tcon fuse might be f101, see if you have about 12 volts on each side, using chassis ground.
      • howardc64
        • Jun 2017
        • 632
        No backlight flash ever.
        Uploaded more clear tcon pic on original posting. Fuse on top left of ribbon connector from main board reads 12v on both sides as well as the probe point to the right (Board says F1 5A/32V, I've seen mislabel before on Vizio TV boards)
        • R_J
          • 9556
          You already proved your t-con is ok with the flashlight test, You likely have an open backlight string causing the backlight driver to shut down.
            • 12206
            • U.S.
            yep, he did, i read it and forgot it before post #3,
            • howardc64
              • Jun 2017
              • 632
              3 more data point before diving into panel tear down for backlight access.
              From power off to on
              A_DIM 0.7v -> 2.6v
              P_ON 3.1v -> 3.1v (never changes)
              P_DIM 1.2v -> 3.4v
              Don't know whats normal.
              And just to double check, should be able to drive the LED strings from the PSU connector to see if they are good before panel teardown right? Should see 90v? (15 x 6v LED / string)
              • neilc6
                • Nov 2015
                • 1550
                Time to buy an LED tester if you want to repair TVs. Easy to confirm an open circuit in the string plus you can power the LEDs independent of the power supply to check the screen before ordering new strips. Power the strips with the connector unplugged.
                • howardc64
                  • Jun 2017
                  • 632
                  Re: TCL 55S423 powers on + LCD display + sound but no backlight
                  Yeah got a tester on order. Will confirm failed LED strings before ordering parts + disassembly. Report back after. Failed backlights seems to be common problem on these TCLs.
                  Also corrected the model # 55S423 but unfortunately can't change original post title.
                  • howardc64
                    • Jun 2017
                    • 632
                    UPDATE
                    LED tester came in and sure enough 1 string has an open while the other string lights up fine towards 80v+
                    Waiting for 6V LED to arrive and will try to do individual LED repair on this one. Will post follow up later.
                    • neilc6
                      • Nov 2015
                      • 1550
                      Individual LED replacement is never recommended especially with new strip prices low with lots of sellers on Aliexpress and ebay. All the LEDs have wear and will eventually fail. Every time you open up the TV, you risk damaging the panel. Think that model only uses two rows of strips.
                      • howardc64
                        • Jun 2017
                        • 632
                        Good point. Although this model cause me some pause. Some show the white reflector sheet is hard to take out without damage resorting to cutting rather than peeling off with the "glued"? back. Thus my reason to think single LED repair. Also all the aftermarket replacement strips I've used seems cheaper construction than original usually with thinner metal strip. I've often wondered their longevity. But I suppose OEM already been used awhile as well.
                        Regardless, turning down backlight is must after the repair
                        • howardc64
                          • Jun 2017
                          • 632
                          Tried single LED replacement. Definitely not for the first timer.
                          - Cutting off old LED left a copper plate that shorted anode/cathode. Not sure why. Perhaps was part of the old LED? Had to exacto knife to separate.
                          - Soldering iron is impossibly difficult. LED bar is a big heat sink taking away heat on the iron tip. Difficult to mount LED flat rather than tilted on one side.
                          - LED color temperature don't match
                          - Result is lightly tilted LED and likely higher than normal height under the lens
                          - Hot air requires low temp solder paste (had none on hand). Otherwise, too easy to toast the reflective white paper nearby.
                          Combined all these issues produced a circular ring bright spot when viewing flat bright colors in the replaced LED region.
                          Back to the entire LED bar replacement method. On this set, does require cutting the white reflective paper to get the bar out without ripping it.
                          • howardc64
                            • Jun 2017
                            • 632
                            One more note on reassembly for future DIYers.
                            The rear frame that LEDs/diffusers/LCD panel itself mounts flex a little. When placed on its back, top and bottom of the frame where diffuser sheets are slotted into the keys will not go back in properly due to this flex. Need to place a small support on the rear top to eliminate this flex. Height of the support probably depends on if boards are removed (I used a 1.5" tall support with boards removed)
                            • howardc64
                              • Jun 2017
                              • 632
                              UPDATE
                              LED bars came in from Aliexpress ($12). Came with 2sided tape on the back. Installed it and here are few notes for future efforts
                              - Seems impossible to remove the white reflector paper above the LED bars without damaging it. So I did some cuts to get the bars out. Cuts are all in the center of the paper bridge over the LED bars. Plastic diffuser stands goes over some of these bridges. So if careful, can get old bar out and put new bar in without any problem.
                              - Old LED bars are only glued on under each LED and taped to the tub in 2 sections. A thin blade tool cut the bar glue pretty easily from under the bar. Clean the tool after each cut as the black glue will make their way onto the white reflector sheet (pick off any that gets on with tweezers) Xacto knife cut the tape on the edge of the bar. Some tapes are under the reflector sheet bridge so need to lift up the cut bridge to cut the tape. See pics.
                              - LED on 1 of the old string was warmer color than the other so best to just replace all bars.
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                I've replaced individual leds before. Color never matches. New are always bluer. I think they yellow as they age.
                                • triplefour
                                  by triplefour
                                  09-13-2023, 10:43 PM
                                • Ierwin
                                  by Ierwin
                                  05-13-2025, 03:31 PM
                                • ChaosLegionnaire
                                  by ChaosLegionnaire
                                  09-13-2022, 09:02 AM
                                • Mgiffune
                                  by Mgiffune
                                  06-09-2024, 10:28 AM
                                • Audeze
                                  Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                  by Audeze
                                  I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                  Does...
                                  10-06-2024, 08:54 PM
