Borderless TV screens (without bezel)
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Hi guys, I have a friend that needs help but does not have access to the internet. He has these borderless tvs whose lcd screen is glued into place. A lot like a cell phones. Now he got it loose and fixed the backlights but does not know what to glue it with. He used white silicon but it cam loose again. What is the procedure?
    Regards
    Angelos
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: Borderless TV screens (without bezel)
    I know this won't help but..
    What a god, this man had no internet acess and managed to remove a glued panel without destroying it.
    In phones the procedure is either a very thin double sided tape then applying heat and pressure, or "B7000" glue with pressure, for this tv it should be the same.
    • djmka
      • Aug 2021
      • 35
      • England
      Hi. I've just replaced the backlights on a 55" Hisense "bezel-less" television and used 3mm wide, double-sided 3M tape to bond the screen to the frame. Initially the panel remained attached to the housing and I was very pleased. However, when I checked a few hours later I was horrified to see the panel had detached itself and was leaning at 20 degrees. Before fitting the tape I ensured the housing and screen were clean and none of the original foam tape was present. I honestly thought that using 3M tape, a world leader in adhesives, would guarantee the panel remained in place. Can someone pleased tell me what else I need to do or send a link of a video showing me the correct process.
      • diif
        • Feb 2014
        • 6978
        • England
        Which 3M tape did you use and where did you purchase it from ?
        • djmka
          • Aug 2021
          • 35
          • England
          Hi Diff. Thanks for your question. I bought it on EBay and it has a 3M code of 9448A. I have uploaded a photo for your reference
          Darren
          • diif
            • Feb 2014
            • 6978
            • England
            You've used the wrong tape. That's not strong enough and coming from ebay is possibly fake.
            It's some 3M VHB tape you should be using,
            • djmka
              • Aug 2021
              • 35
              • England
              Thanks again for the advice. Do you know where I can buy 3mm VHB ?
              • vinceroger69
                • Mar 2012
                • 6714
                rs online
                • djmka
                  • Aug 2021
                  • 35
                  • England
                  Thank you Vince. I'll let you know how it goes.
                  • djmka
                    • Aug 2021
                    • 35
                    • England
                    Quick update - the tape that vinceroger69 suggested worked perfectly. Thanks again to all who those who respond to cries for help.
                    • Bazfletch3
                      • Jan 2024
                      • 10
                      Hi all, Im also having trouble with some double sided tape and a bezel-less LCD. I ordered 3M VHB tape - although I did order it from ebay.... It was incredibly stretchy and didnt stick well at all. Is it likely that I just got fake crap quality tape? Is there any other comparable tapes I can look at? (Tesa, etc) as Im having trouble getting a small qty of 3M VHB tape from any reputable retailer here. My other option is try try and glue it with T-7000 glue; does anyone have positive experience doing this on a bezel-less screen?
                      Baz
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        VHB stands for very high bond. If it wasn't sticking, it's fake.
                          • 21465
                          I have some genuine tape and always had problems with it until i started using adhesion promoter.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            This is the tape i have used on the last two tapped in screens it seems too work well https://www.ebay.co.uk/itm/115518580...r=415540932129
                            • RetroComputingGrotto
                              IBM LTO 7 Tape Drive - Dust Sensors??
                              by RetroComputingGrotto
                              I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                              I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                              09-19-2024, 01:54 AM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • triplefour
                              LG 75UN8570AUD panel issue fixed with tape.
                              by triplefour
                              I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                              add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                              07-17-2023, 10:22 PM
                            • diamon
                              Issues with new Surface Pro 5 screens
                              by diamon
                              I have three Microsoft Surface Pro 5 model 1796, with all cracked screens.
                              Have bought from Aliexpress three new screens, the part numbers from my and the seller are the same:
                              Bad working China screen part number:
                              Good working own screen part number
                              Error I get with the bad working China screen:
                              No error with the good working own screen:
                              All the three China screens (all the same exact part numbers) produce the same error in Device manager. Have also performed a clean installation...
                              06-25-2023, 01:41 PM
                            • alltvrepairs
                              Hisense 55AS6G screen double sided tape required
                              by alltvrepairs
                              I need to replace the LEDs of this TV. The screen is glued with double sided tape. This video shows the proceudre required.
                              I need a source for this type of double sided tape adhesive please.
                              https://www.youtube.com/watch?v=bN6g...nel=QUADRA-NET
                              Tks!
                              07-17-2025, 09:32 AM
