Philips 55PUS6262 no picture
  • mrsith
    • Mar 2021
    • 146
    • Wielka Brytania
    #61
    Re: Philips 55PUS6262 no picture
    The 6703 with it's t-con originally gave normal picture, so I highly doubt the ribbon was burned then. 6162 every single panel board component has been tested for shorts, after replacing 1 cap as mentioned earlier in this thread no more shorts were present.
    I am not going to touch 6162, gonna start with looking for shorts on 6703's Tcon. Worst case scenario I'll just risk buying a fresh Tcon for it.
    • mrsith
      • Mar 2021
      • 146
      • Wielka Brytania
      #62
      So yeah, I did risk getting another tcon to 6703. Nothing changed at all. No picture when both ribbons connected, half picture with purple artifacts (reacting to touch) on one side. Whitish-greyish panel if only the bad side connected. Tried cut tape once again, wasn't able to get any picture at all on the bad side.
      Could someone with knowledge explain what the hell is happening with this TVs? How is that possible? There are no shorts at all on panel boards on 6703 and never were any. It was absolutely fine until I tried putting its tcon to 6162. After that the TV is basically bricked - thought just the tcon got fried in 6162, but apparently there's something bigger going on? Main boards fried on both of them? Any ideas at all?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4546
        • Italy - Milan
        #63
        Don't listen about fantasy advices, bad caps don't produces artifacts, yours is probably a bad gate driver issue, must provide pictures of what the screen apears when problems are there, no blind diagnosis..
        • mrsith
          • Mar 2021
          • 146
          • Wielka Brytania
          #64
          Couldn't upload video here, hope this is acceptable:
          https://streamable.com/sc2u1v
          The problems in this TV started when I took its Tcon to 6162 for a second. After reinstalling in 6703 this is the result. Tried to buy and install another tcon, same problem. Tried cut tape method again, no joy.
          By the way, accidentally smashed the 6162 screen when moving stuff in the workshop, so only 6703 left in ring. This video and all the recent posts refer to 6703.
          Could a chain reaction occur? Like: 6162's bad panel/board fried the 6703's Tcon, which further fried 6703's panel/board which fries any new Tcon I throw at it?
          Many many thanks for getting back to this thread, I started considering scrapping it.
          • nomoresonys
            • 12323
            • U.S.
            #65
            did you do a close inspection of the cof's on 6162, some of those symptoms seem like a burnt cof, had a tricky one not long ago, where the outside looked fine but the inside meaning other side of the board and cof was obviously burnt. I know it's busted now but a bad cof may have been the problem with that one.
            • mrsith
              • Mar 2021
              • 146
              • Wielka Brytania
              #66
              6703 now acts exactly the same as 6162, so I should be able to find something on it. I did close inspection on 6162's COFs, with microscope, couldn't find any burns or cracks whatsoever. I will doublecheck that on 6703.
              I still don't get why (and actually how?) touching the disconnected flex cable (the one between t-con and panel) results in artifacts showing up on working side. Doesn't seem to make any sense.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4546
                • Italy - Milan
                #67
                The video is very poor, one simple rule: if the subject is low and wide not use a cellular in portrait but in landscape (horizontal)..
                • mrsith
                  • Mar 2021
                  • 146
                  • Wielka Brytania
                  #68
                  Apologies, uploaded wrong one by mistake. This should be much better:
                  https://streamable.com/o6v4jw
                  The patterns mostly don't show up on their own until I touch the flex. Mostly.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4546
                    • Italy - Milan
                    #69
                    Tried to read all thread but it's difficult, i'm at page 3.. wait.. the thing i can say for now is, if you have tested a maybe good tcon on a tv that uses a different tcon and have upgraded tv, the tcon firmware sometimes can be changed, this case with wrong one.. so returning back to its original place it's a problem.. try upgrading the present tv and hope the new software contains also tcon software..
                    • mrsith
                      • Mar 2021
                      • 146
                      • Wielka Brytania
                      #70
                      Both TVs uses exactly the same tcon. I was afraid that what you said might be the case, and did manually flash firmware to rule it out.
                      Especially that after this I've bought another tcon, from the same model (6703), and the effect was/is the same.
                      • Patrick501
                        Philips 55PUS6704 no picture, backlight ok
                        by Patrick501
                        I'd like to repair a Philips 55PUS6704.
                        It turns on and you can see the backlight, hear the sound but no picture.
                        When I disconnect one of the T-con cables, half of the screen turns white.
                        right cable disconnected= right side white
                        left cable disconnected= left side white
                        When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
                        There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
                        Also you can notice one single...
                        11-12-2025, 08:46 AM
                      • Rauni
                        Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                        by Rauni
                        Hello, this is my first post on this forum, and my first attempted to repair a TV.
                        My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                        Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                        Read also that we should test what happens if we...
                        10-01-2023, 12:06 AM
                      • Schwoin
                        Philips 243v5lhsb00 Monitor Picture too bright
                        by Schwoin
                        Hey everyone,
                        the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                        While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                        you can see them on the top half of the photo.
                        At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                        03-21-2023, 12:40 PM
                      • madyoyo
                        Philips 37pfl560: Yellow picture
                        by madyoyo
                        HI.
                        I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
                        Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
                        05-30-2025, 10:16 AM
                      • mecha1166
                        Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
                        by mecha1166
                        I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
                        07-03-2024, 05:03 PM
