Philips 40pus6809/12 qn141e
  • kiko1
    • Apr 2016
    • 48
    • croatia
    I am stuck with LOGO philips on this TV. "autorun.upg" does nothing.
    After power up, shows logo "philips" then it turns off backlight and logo(black screen).If I try to turn it off with remote red led blinks and turns on, so I supose it really turns off.
    someone point me to right direction for download upgrade loader to try it? :-)
    tnx
  • lotas
    • Jan 2016
    • 4899
    • Russia
    Re: Philips 40pus6809/12 qn141e
    To reset the settings to factory settings if the TV does not turn on.
    It is necessary to unplug the plug from the socket, press the joystick behind the TV down, insert the plug into the socket, and after two blinks of the indicator, release the joystick. These steps will bring up the factory reset menu.
    • William1967
      • Nov 2017
      • 217
      • Netherlands
      The upgrade loader is a bit to big to place here ( zipped 460Mb) if you know a way I can send it to you please contact me.
      • Diah
        • Feb 2013
        • 6614
        download this QN141E _012.003.086.128 (Date published: 2018-01-09) and install to get your tv back.
        • kiko1
          • Apr 2016
          • 48
          • croatia
          I already tried this with joystick...nothing.
          Tnx very much guys...will try that file and get back with info
          • kiko1
            • Apr 2016
            • 48
            • croatia
            TV is back to life....
            tnx for help, I really appreciate that.
            • alpersen
              Philips 40 PUK6809/12 Backlight turns off after 10-20 seconds
              by alpersen
              Hello
              Mother called and said TV turns off after switching on. So after turning on Philips logo shows and probably 10-20 seconds image disappears, sat receiver is connected and sound is heard from source. So I turned on my phones light and I can see the image it seems backlight was off after some time. I dis assembled the cover hoping to see a distinc cap blown or leakage. Here are photos I took (I was after 22:00 pm and maybe some of them are dark). Should I order and change caps on the power circuit or what would you recommend? Thanks...
              07-25-2024, 12:50 AM
            • ressof
              Philips 47PFL4606H/12 turns off after 10 minutes
              by ressof
              Hi
              I have a Philips LCD 47PFL4606H/12 that turns off after around 10 minutes and then i cant turn i back on again without removing the power cord and attach it again. Then it turns itself off again after some minutes. When this happens the red led that usually indicates standby mode is off.
              Can it be the same problem as in this thread?
              https://www.badcaps.net/forum/showth...ght=47pfl4606h
              01-23-2023, 12:52 AM
            • samtron786
              philips 46pfl8605k/02 Upgrade Loader???
              by samtron786
              Hi
              Philips 46PFL8605K update failed searching for the
              upgrade loader.
              I can't get into recovery mode, it just goes on and off.
              Many Thanks
              01-14-2023, 11:55 AM
            • Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
              by Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
              03-15-2024, 09:37 AM
            • www
              LG L192WS-BN backlight turns off after 1 second
              by www
              I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
              I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
              03-24-2024, 05:26 PM
