philips 46pfl8605k/02 Upgrade Loader???
  • samtron786
    • Aug 2016
    • 161
    • germany
    Hi
    Philips 46PFL8605K update failed searching for the
    upgrade loader.
    I can't get into recovery mode, it just goes on and off.
    Many Thanks
  • samtron786
    • Aug 2016
    • 161
    • germany
    Re: philips 46pfl8605k/02 Upgrade Loader???
    Hi
    Philips 46PFL8605K failed after update.
    I can't get into recovery mode, it just goes on and off, nothing else happens.
    Many thanks
    • samtron786
      • Aug 2016
      • 161
      • germany
      that's done
      • William1967
        • Nov 2017
        • 214
        • Netherlands
        For this model there is no recovery software and there is no recovery mode. There is only firmware available.
        • volinakis
          Chromebook recovery failed - how to fix it
          by volinakis
          So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
          Finally I found a site where they suggested to try with an older image and ... it worked!
          What I did:
          - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
          09-18-2023, 03:26 PM
        • tommy97
          iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
          by tommy97
          we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
          Any ideas what might've...
          04-20-2024, 04:48 AM
        • bohaboha
          PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
          by bohaboha
          Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
          how to fix it thanks
          02-05-2025, 09:23 PM
        • rakonja
          PHILIPS 42PFL7008k/12 HARDWARE UPGRADE(REQUIRED HARDWARE/EXPERIENCES)!!
          by rakonja
          Hello everyone! I am the owner of a Philips 42PFL7008k/12 TV! It served me well all the years. Sometimes it used to get "stuck", after which I used to disconnect it from the voltage, hold the power button on the device for about 30 seconds, and after turning it on again, it worked like new!Only once it threw something like no software!Now it happened that it won't turn on anymore, the red LED blinks twice!Do you have any suggestions? They are probably not cost effective to repair, but I am sorry to get rid of it, it has served me well and looks like new!The only downside is the slow...
          09-07-2023, 09:50 AM
        • michelhadid
          Crelander DS16 Dual screen BIOS Update failed recovery with CH341A
          by michelhadid
          Hey guys. Michel here. I´m trying to recover a Crelander DS16 Laptop (i7 10750h dual screen laptop, ZENBOOK DUO Clone).
          Laptop lost power and failed a BIOS Flash mid flash with AFUWIN/DOS. I of course made a backup beforehand, however, i can´t flash with AFUWIN/DOS now since it doesn´t boot/post anymore (black screen, fans on). I´ve read the BIOS chip (W25Q80DVSIG) with a CH341A Programmer, but AFUWIN Bios backup is 12MBytes and the CH341 read is a 1Mbyte file. I have compared both files and tried changing some data around with a hex editor (used WinOls to compare and edit) but...
          10-30-2023, 06:09 PM
