Hisense 65H6570F Logo shows then turns off
  • dskall
    • Oct 2016
    • 2905
    • usa
    #41
    Re: Hisense 65H6570F Logo shows then turns off
    Led tester would probably tell you. It's not always reliable since it doesn't load the leds like tv's power supply.
    • Diah
      • Feb 2013
      • 6379
      Originally posted by USmechS
      Is it at all possible that the difference in voltage is due to lower port having less LEDs to drive? 86V is very close to being 2/3 of 136V. If the TV has 5 LED strips, and the top port driving 3 of them and the bottom 2 of them, 136-86 split is not awful.
      Again, I am wishing this not be a BL issue since I cannot realistically fix that.
      if you upload good photo on the whole back of the TV , from the chassis design can tell how many strips there and do correct calculation
      from the chart LED BL one channel Max 120V 900Ma. so we have the Group of 136V are over load.. i remarked the 86V as its correct range
      • USmechS
        • Apr 2022
        • 27
        Thank you for the clarification about the voltages. It makes perfect sense.
        I think the TV has 5 strips of LED. the picture of the back of TV is attached. If it is not clear, I can see only 5 sets of pin placements on the back on each side.
        • Diah
          • Feb 2013
          • 6379
          yes its5 strips, so the group will be 2 1/2 strips , so if you are afarid to take the screen apart. i will explain to you here matter and the rest i will leave it to yours creative ideen.
          with out BL socket connected you messured 197V on each group. how ever the chart say max 120 V. so the LEDs are part of the circuit to adjust the output to less than 120V:
          yours messurments after you plugged back the BL socket, you got 137V which its overload and one with 86V which to me normal. so the the one 137 are over load.
          so with out socket Tv will not work as there are overload or open circuit. but if you get now Normal filament lamp we put it in the way of (N) of the groups which are 137V , this mean LED+ will go direct to the strips and the wire of LED- (N) come back to the socket.. we put the lamps one wire to the LED- coming back from strips and the other will go to the socket direct.
          easy way you can try the LED- of the overloaded group cut it before the socket and connect the lamp between. 50 Watt lamp i think will be enough... give try if it work good if not bring the wire back and find some one help with change LEDs
          good luck
          • USmechS
            • Apr 2022
            • 27
            Thank you very much, it is a solution that can work.
            • dayv25
              • Aug 2016
              Could you possibly share the recovery firmware? I have the same model tv with the same exact issue. Did you ever get it fixed?
              • jsdffxf
                • Mar 2023
                • 9
                • 美国
                #47
                The method of restoring hisense to factory Settings: Power off - press the TV button to switch on the AC power and wait for 15 seconds, then the screen will indicate that the system is recovering, you can release the button, wait for 3/5 minutes, if you can't restore the TV, you can only open the TV for repair, in addition, I want a pkg file, thank you!
                • taslan
                  Surface 7 Pro wont boot, shows Logo and immediately turns off
                  by taslan
                  as stated in the title, my surface 7 pro wont boot anymore.
                  When i press the power button it shows the square windows logo for a second and immediately turtns off again.
                  I dont even have a chance to get into bios or boot from usb.
                  While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
                  I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
                  Bought it directly from microsoft and used it now and then and only...
                  01-16-2025, 01:25 AM
                • IIOSOH
                  46PFL5507K/12 - Shows a "Hourglass" logo then turns off the backlight - No sound
                  by IIOSOH
                  I'm trying to fix a Philips TV [46PFL5507K/12] for a friend. A few seconds after turning it "ON" a hourglass appears and stays on the screen for around a second, then the screen goes black again, there is no picture nor sound when i connect via HDMI to my PC.
                  I've opened it up and took a few measurements, but i can't seem to find the correct schematic for this exact model. The official service manual has detailed schematics and info for pretty much every other TV from the series but just some generic information about this exact part number so i measured...
                  04-02-2022, 12:43 PM
                • dragometin
                  Hitachi 40HYC42
                  by dragometin
                  TV Model: Hitachi 40HYC42
                  Power Supply: 17IPS71
                  MainBoard: 17MB95M
                  Panel: VES400UNDS-2D-NO3
                  When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                  I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                  Is there any variants on 17IPS71 power supply's?
                  UART output pins 10 and 12 on scart connector:
                  Code:
                  12:24:04.595
                  08-08-2024, 05:53 AM
                • EazyBone
                  Hisense 55H8F Emmc programming help
                  by EazyBone
                  I am extremely new to programming and dipping into this. I picked up a XGECU T48 Programmer and have the correct socket for EMMC.
                  I took the EMMC off a working main board with no problems and threw it into the programmer. I click analysis IC and it gives me a report (attached) of the current EMMC. Model H26M41204HPR
                  1) I manually found this chip(above model number) in the select IC section of the XGPRO 12.xx programmer software and it had a option for 4 bit and 1 bit. I chose 4... is this correct?
                  2) In the options section point number 2 operation says "30...
                  06-11-2024, 06:03 PM
                • TheQuentincc
                  Dell XPS 9300 (LA-H811P) internal display only shows Dell logo then nothing (everything else works)
                  by TheQuentincc
                  I have a Dell XPS 9300 that's working perfectly fine with an external display plugged, from windows the internal display isn't detected. At boot I can see the Dell logo then when it should display the boot/bios or whatever the screen goes black (no backlight, no image using a flashlight). I tried unplugging everything on the motherboard except the eDP cable but it didn't helped (so it's not the lid sensor). LCDVDD/backlight power are powered down when this happen, PANEL_BKEN_EC and ENVDD_PCH are also down to 0v. It's weird, it almost feels like the motherboard is shutting down the display...
                  06-26-2025, 01:44 PM
