RCA LED46C45RQ,Sound but no Back lights
  • R_J
    • 9514
    Re: RCA LED46C45RQ,Sound but no Back lights
    Originally posted by tennno`
    got 5 v sb rest dead turn on tv got all voltage that are supposed to be there 12v 5v etc.
    Does ETC. mean the BL-ON?
    • tennno`
      • Nov 2013
      • 37
      • usa
      Thank you for all your time.Will get back on after I check it out
      • tennno`
        • Nov 2013
        • 37
        • usa
        bl 1 fast flash then off
          • 12075
          • U.S.
          THIS RIGHT HERE "What does the BL-ON voltage do on CON4" they want you to check the voltage on that pin, when tv is in standby and powered on, it's really pretty simple.
          • tennno`
            • Nov 2013
            • 37
            • usa
            Right now I have the tv apart checking the back lights
            • tennno`
              • Nov 2013
              • 37
              • usa
              #26
              5v
              • tennno`
                • Nov 2013
                • 37
                • usa
                #27
                Let me check again don't want to tell you wrong
                • tennno`
                  • Nov 2013
                  • 37
                  • usa
                  #28
                  gnd 0
                  adj 5v
                  BL-on 5v win on , 0 win off
                  • tennno`
                    • Nov 2013
                    • 37
                    • usa
                    #29
                    Bl-on 5v
                    • tennno`
                      • Nov 2013
                      • 37
                      • usa
                      #30
                      back lights
                        • 12075
                        • U.S.
                        #31
                        Make sure all the backlight connections are clean and not loose and have no resistance.
                        • tennno`
                          • Nov 2013
                          • 37
                          • usa
                          #32
                          all seems good
                            • 12075
                            • U.S.
                            #33
                            Did you measure the voltage on the big cap both in standby and powered up? CAREFUL HIGH VOLTAGE, for those looking on that might not know.
                            • tennno`
                              • Nov 2013
                              • 37
                              • usa
                              #34
                              no not sure on how to do that. Are you talking about the big black cap on the hot side? there is only one that I can see
                              • R_J
                                • 9514
                                The voltage across the main filter (EC101) will be the same in standby or ON (165vdc) there is no pfc circuit.
                                  • 12075
                                  • U.S.
                                  #36
                                  not sure but some of your solder joints look a little suspect on that board, might want to touch them up a little.
                                  • tennno`
                                    • Nov 2013
                                    • 37
                                    • usa
                                    #37
                                    172.9 sb
                                    169.3 on
                                      • 12075
                                      • U.S.
                                      #38
                                      examples of bad joints: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
                                      • tennno`
                                        • Nov 2013
                                        • 37
                                        • usa
                                        #39
                                        Don't see any I got a different board today its doing the same thing joints on this board looks good
                                        • R_J
                                          • 9514
                                          Since you have the panel off, power up the led's with the TV's power supply and not if any led's are not the same brightness before it shuts down.
                                          The backlight tester only provides about 10~15 ma of current and also does not monitor the current like the power supply board does, I suspect a led is failing when provided with a higher operating current.
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                          • dronerat
                                            Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                                            by dronerat
                                            Hi Guys,
                                            This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                                            PSU: L48S6 FHS BN44-00807D
                                            T-Con: BN95-01937A
                                            Panel: CY-GJ048HGLVLH
                                            MB: NA (Currently as the TV is assembled and forgot to take picture)
                                            As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                                            It was sent to an authorized service for repairs and returned with the...
                                            05-15-2020, 08:03 AM
                                          • Musictuff
                                            70UH6350 Back lights
                                            by Musictuff
                                            My LG tv started going dark a few seconds after powering on. I replaced the led back lights after doing the flashlight test. The problem I am having now is the bottom of the screen is really bright and the middle to the top of the screen is darker. I can actually see the individual leds at the bottom of the screen. Not sure why that is. I've tried lowering the backlight setting but I can still see the led's at the bottom, and the middle to the top of the screen gets even darker.
                                            04-09-2023, 11:45 AM
                                          • Christos Tsiligiannis
                                            Marian Trace Alpha sound card repair help
                                            by Christos Tsiligiannis
                                            Hello to the forum.
                                            My name is Christos, I am new to the forum here and i am posting from Greece.
                                            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                            So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                            11-18-2024, 05:26 AM
