RCA LED46C45RQ,Sound but no Back lights
  • tennno`
    • Nov 2013
    • 37
    • usa
    #41
    Re: RCA LED46C45RQ,Sound but no Back lights
    With tester all lights lite at same brightness . when hooked up to power board lights don't come on
    voltage drops at connector
    • R_J
      • Jun 2012
      • 9625
      If you have voltage at the connector you should have at least a flash of the led's
      • tennno`
        • Nov 2013
        • 37
        • usa
        #43
        Yes 1 flash then nothing
        • nomoresonys
          • 12331
          • U.S.
          #44
          did you check the leds individually? might give a clue.
          • tennno`
            • Nov 2013
            • 37
            • usa
            #45
            no
            • tennno`
              • Nov 2013
              • 37
              • usa
              #46
              Already put it back together
              • nomoresonys
                • 12331
                • U.S.
                #47
                thinking most of the time, that one flash means bad backlight led/s or poor backlight connection.
                • tennno`
                  • Nov 2013
                  • 37
                  • usa
                  #48
                  Don't know how to put more power to them other the tester that will tell
                  • nomoresonys
                    • 12331
                    • U.S.
                    #49
                    when testing with backlight tester, did you test thru the backlight cable going to the backlights or right on the strips, meaning did you verify continuity of the cable?
                    • tennno`
                      • Nov 2013
                      • 37
                      • usa
                      #50
                      connector
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        #51
                        Originally posted by tennno`
                        Don't see any I got a different board today its doing the same thing joints on this board looks good
                        You had 0v at led connector with old board and now you have voltage at led connector with new board. Correct? And now you get a flash of backlights?
                        • tennno`
                          • Nov 2013
                          • 37
                          • usa
                          #52
                          Yes but voltage drops off
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            #53
                            Ok then you need to do what was suggested in post 40.
                            • tennno`
                              • Nov 2013
                              • 37
                              • usa
                              #54
                              Reopened it and tested each led found 1 bad (dead)trying to locate a new strip
                              IC-A-KJAB46D444 (8 leds on strip)
                              flashes to fast to tell if brightness is different
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                #55
                                https://www.youtube.com/watch?v=Y2Tv...ck%27sTVRepair
                                • tennno`
                                  • Nov 2013
                                  • 37
                                  • usa
                                  #56
                                  Thanks All you guys for your help .I'll get back after I get different back lights and let you know.
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • JohnML1975
                                    Samsung UA50TU8000W no picture and no sound
                                    by JohnML1975
                                    Hello All
                                    have seen posts on this model in here but my problem sounded different so thought i would create a thread
                                    TV will not turn on
                                    There is no standby light
                                    When I press ON button for remote the red standby light does flash but no picture and no sound
                                    From the back of the TV I can see the red light on the back of the mother board
                                    Holding torch to the screen I cannot see a picture
                                    I removed the back cover
                                    Observing the boards I cannot see any damage
                                    I disconnected the main board from the power supply
                                    the back...
                                    08-30-2025, 09:40 PM
                                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                    I am comparing them to a brand new one that I installed
                                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                    I going to let it run for several days before I remount back on the wall next to the...
                                    09-05-2024, 06:48 PM
                                  • dronerat
                                    Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                                    by dronerat
                                    Hi Guys,
                                    This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                                    PSU: L48S6 FHS BN44-00807D
                                    T-Con: BN95-01937A
                                    Panel: CY-GJ048HGLVLH
                                    MB: NA (Currently as the TV is assembled and forgot to take picture)
                                    As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                                    It was sent to an authorized service for repairs and returned with the...
                                    05-15-2020, 08:03 AM
                                  • Musictuff
                                    70UH6350 Back lights
                                    by Musictuff
                                    My LG tv started going dark a few seconds after powering on. I replaced the led back lights after doing the flashlight test. The problem I am having now is the bottom of the screen is really bright and the middle to the top of the screen is darker. I can actually see the individual leds at the bottom of the screen. Not sure why that is. I've tried lowering the backlight setting but I can still see the led's at the bottom, and the middle to the top of the screen gets even darker.
                                    04-09-2023, 11:45 AM
