Sony Bravia KDL-32L4000 vertical lines
  • JimD
    • Dec 2011
    Re: Sony Bravia KDL-32L4000 vertical lines
    Watch this Guy
    Bad Panel
    http://www.youtube.com/watch?v=Qj51BkS9d-0&feature
    • hsmr2
      • Feb 2012
      Originally posted by chrisbarnes72
      i have a smilar problem on a KDL-40S4100. see attaced pic
      Did you ever get this issue resolved. I have the exact same problem and additionally my ethernet jack wont work anymore. I have the KDL-46Z4100.
      • tmwcpwnz
        • Mar 2012
        Dealing with a similar issue, however in my situation when I allow my set to warm up for 20 minutes or so, the vertical bleeding lines fade away, and I am left with 2 rows of "semi" dead pixels. It's livable. Anyone trace down the bad component on the t-con board?
          Please read this about SONY T-CON/LCD troubleshooting.
          • tibimakai
            • Jan 2012
            • 3680
            I found one(kdl-46z4100) that is for sale and the issue is different, it seems that the right side is darker, but viewable. This is for sure tab issue?
            • visionbluedemon
              Help. Sony kd-65x85dj vertical lines
              by visionbluedemon
              First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
              Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
              tried blocking LC lines too, but same results
              is it lcd panel issue or tcon board issue?...
              07-25-2025, 04:56 AM
            • gpo23
              Sony KDL-40V3000 - Vertical lines
              by gpo23
              i order a t-con because i had bad colors on my SONY KDL-40V3000 :
              With the new t-con the color are good but there are vertical lines on all the screen :
              I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
              Is there a way to fix the vertical lines on the new t-con ?
              Thank you for your help
              gpo23...
              10-04-2023, 09:11 AM
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
            • thstuff
              SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
              by thstuff
              This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
              Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
              1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
              2) Waited 30 seconds, then pressed remote Power button and "Select language"...
              01-30-2023, 05:01 PM
            • dustman1747
              Sony XBR-65X900H vertical lines
              by dustman1747
              I have acquired a Sony XBR-65X900H to try and fix. It probably was a complete no power situation. The main board was replaced and the TV started turning on. I now have start sounds and backlights, but no image. I've replaced the t-con with no improvement. Cables all appear to be ok and seated properly. The TV took a firmware update and hard reset but neither helped.
              Using the tape trick I can get both side to display combinations of colored vertical lines. There is no change in the stripes and the pattern always appears the same. If I add additional tape strips I can get the screen...
              09-18-2023, 09:05 PM
