Hisense 65R6E3 - Power cycles no backlight
  • jason123
    • Oct 2015
    • 1069
    Hi folks.. Would appreciate your help.
    Hisense TV that doesn't turn on (no pic, no backlight)
    Flashlight tests shows activity on the screen (Hisense ROKU) then off then again.
    On the connector from PS to main, I see Vstandby (2.5 V), VAMP (16.9V) and 12V (11.86 V)
    As the TV cycles, VAMP goes from 16.9 to 17.6V then back to 16.9V
    Any thoughts? never seen a standby voltage as low as 2.5V. Not sure if backlight is bad, but that doesn't explain the reboot cycle - right?
  • neilc6
    • Nov 2015
    • 1550
    Re: Hisense 65R6E3 - Power cycles no backlight
    The Roku TVs when first plugged in, turn on, take a minute or two to boot and then go into standby mode. The TV needs to be turned on a second time to get out of standby. I would suspect bad LEDs. Vstandby may be a logic signal from main to go in and out of standby.
    • jason123
      • Oct 2015
      • 1069
      Thanks Neilc6. I have attempted a restart. Tv is non-responsive to Remote it seems. Just stays in the on / off cycle (No backlight, just flashlight test screen activity)
      Do bad LEDs explain this?
      • neilc6
        • Nov 2015
        • 1550
        If you have no backlight, backlights are suspect. With a LED tester you can power one string of the backlights independent of the power supply so at least you can see the screen.
        • jason123
          • Oct 2015
          • 1069
          All the strips are connected together, so one string, and not lighting up.. so I'm hoping this is it!
          • jason123
            • Oct 2015
            • 1069
            Thanks neilc6 ... LEDs were the problem, though I've never seen a TV that continuously reboots and doesn't respond to remote / Push buttons because LEDs went bad.
            Anyway, it's up an running with repaired set (lenses never align right) so a new LED set on-order.
            Thanks again
            • dskall
              • Oct 2016
              • 2905
              • usa
              I install lens with led lit, looking straight down on them. New set is best option though.
              • ajshoe
                ajshoe
                • Dec 2012
                • 477
                • usa
                just a heads up on this set - extremely hard to get display apart as this is a glued display screen onto a black plastic bezel. In my opinion - not worth fixing. This can easily turn into a 3 hour repair !
                • EazyBone
                  • Jun 2023
                  • 1348
                  • United states
                  Suction cup 6-8 inches from bottom pull the buffer boards and tape them onto screen with masking. Take cardboard business card and slowly get under front corner while lightly lifting suction cup. Slowly go around the edge moving the suction cup to get a little lift while sliding the card. Haven't broke one yet.
                  • ajshoe
                    ajshoe
                    • Dec 2012
                    • 477
                    • usa
                    That's exactly the way I removed the screen. After doing that though I realized that removing the black bezel with the screen still attached would be much easier and then you don't have to clean the 3mm tape off both surfaces and re-attach new 3mm tape. Has anyone tried this method ?
                    • jason123
                      Hisense 65R6E3 double-image / horizontal strips - TCON?
                      by jason123
                      Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                      07-19-2025, 08:07 AM
                    • Coolgoodman
                      Faulty Hisense 85Q6NAU TV
                      by Coolgoodman
                      85” Hisense TV
                      Greetings,
                      Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                      Dear TV technicians of forum, I hope this message finds you well.
                      I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                      I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                      07-24-2025, 03:02 AM
                    • ShahZaib Ghumman
                      Can I Swap Screens Between Two Hisense 75” QLED TVs?
                      by ShahZaib Ghumman
                      Hey folks,
                      I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                      A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                      So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                      03-25-2025, 10:59 PM
                    • nono34
                      Hisense stuck in Colors cycle like test pattern.
                      by nono34
                      I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                      I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                      10-24-2024, 04:31 PM
                    • dabushar
                      Hisense A6100 Files Request
                      by dabushar
                      Hi guys, I want to try revive a motherboard for a hisense 55 that only lights up the motherboard. does any one have the emmc files ? any help is appreciated. i have seen the emmc pinout on kenotrontv https://kenotrontv.ru/files/file/746...ag78207918roh/
                      08-18-2025, 03:57 PM
