LG 39LN5400 no power
  • unimatrix93
    • Oct 2021
    • 360
    • Magyarország
    #41
    Re: LG 39LN5400 no power
    Originally posted by lotas
    I don't know about IC1903, I need to compare datasheets, what's the difference. Look at the resistors where it should be, solder it where it should not be, then remove them.
    Still not working.
    Do you have SPI and EEPROM files for this TV?
    One of them might be corrupt.
    • lotas
      • Jan 2016
      • 4883
      • Russia
      #42
      Is this the motherboard number?
      • unimatrix93
        • Oct 2021
        • 360
        • Magyarország
        #43
        Yes it is!
        • lotas
          • Jan 2016
          • 4883
          • Russia
          #44
          try
          • unimatrix93
            • Oct 2021
            • 360
            • Magyarország
            #45
            try
            ITS WORKING!!!! 😍
            It's turned out that the ISP software were bad. After flashing the software you sent me the display turned to life!
            After many painful hours... rebuilding half the mainboard. Moving caps, resistors and ICs left-to-right.
            My poor CH341A IC clipper dies halfway the procedure...so I had to desolder and resolder the ISP chip again and again when I tried flashing it. It was...tedious to say the least.
            A HUGE thank you for you and everyone on this forum who tried to help me!
            You guys are awesome!
            • lotas
              • Jan 2016
              • 4883
              • Russia
              #46
              I'm glad that the time spent was not in vain. Congratulations.
                • 12331
                • U.S.
                #47
                Damn, that's some AWESOME work, very well done.
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • _AcE_
                  JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
                  by _AcE_
                  I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
                  There's no physical damage...
                  08-10-2025, 09:27 AM
                • tony359
                  Global AC logic output - XP Power FleXPower
                  by tony359
                  Hi all
                  I've fixed a couple of FleXPower X7 power supplies. Since they have some logic outputs, I went to test them to make sure all was in order.
                  "Fan Fail" would work when the fan is manually stopped.
                  "Global DC" would change state when I manually adjusted one rail beyond 10%
                  "Global AC" doesn't seem to do anything. To test, I power up the PSU and then I remove power. The 5VSB and Aux rails remain active for quite a few seconds after power is removed. I see the rails collapsing but there is no change in the "Global AC"...
                  06-20-2025, 03:06 PM
