Global AC logic output - XP Power FleXPower
  • tony359
    • Oct 2018
    • 264
    • United Kingdom
    Hi all
    I've fixed a couple of FleXPower X7 power supplies. Since they have some logic outputs, I went to test them to make sure all was in order.
    "Fan Fail" would work when the fan is manually stopped.
    "Global DC" would change state when I manually adjusted one rail beyond 10%
    "Global AC" doesn't seem to do anything. To test, I power up the PSU and then I remove power. The 5VSB and Aux rails remain active for quite a few seconds after power is removed. I see the rails collapsing but there is no change in the "Global AC" signal. The manual says that the signal should change 5ms before there is "loss of regulation". I have two of these PSUs and they both show the same. I've tested as the manual says, I read 5V until the 5V line dies. I still read 5V while watching the 24V DC output collapsing.
    Chances are they have the same fault - but could it be that I am misunderstanding how this signal is working?
    Thanks!
  • CapLeaker
    Leaking Member
    • 8344
    You may have to load the output with something, What is it? Sounds like a medical or a special PSU of some sort.
    • tony359
      • Oct 2018
      • 264
      • United Kingdom
      It's a modular power supply, it can be configured from Digikey etc to whatever you want in terms of currents and voltages.
      https://www.xppower.com/product/fleXPower-Series
      I don't think the load is the issue here - but I can try, thanks. The idea with the AC Global signal is that if the PSU has a compromised primary, the standby electronics will sense it and won't even try to turn on the secondaries - and will also log/display the issue.
      "Global DC" logic works. There is an LM339 where the logic happens which I understand is a voltage comparator. Something might be happening there I guess. I have traced the "Global AC" logic to a pin which is an output of two inputs. I'll check
      - Whether the optocoupler is actually getting a signal (maybe the LED is broken? On both PSUs though?)
      - Whether any signal is coming out of the LM339
      - What kind of signals are coming in the LM339
      So far I haven't identified where the signal to monitor is coming from.
      • CapLeaker
        Leaking Member
        • 8344
        Problem is that the logic is programmable or settable. You can set it high or low output. Sounds there has to be something else on the input that makes the output go the other way.
        the global AC fail does do nothing to the psu secondary. It should go to a main board that this power supply powers and tell the computer for example stop reading and writing and lift up the heads on a HDD. So there should be an output on the connector. Kinda same thing than the Power OK pin on an ATX power supply.
        • tony359
          • Oct 2018
          • 264
          • United Kingdom
          there are some jumpers at the back, you see them closer to the optocouplers. I suspect they set how the logic works. I don't see anything programmable on that PCB.
          Yes, Global AC Fail doesn't do anything to the secondary, it monitors (I guess) the 390V DC and sends a "Global AC Fail" signal when it goes below a certain level to instruct the device connected to the PSU to take action.
          OR - it could be one of those DC modules sensing the DC voltage in and reporting it back to the logic.
          So far I haven't been able to see where this logic is getting the signal from but all the traces arriving to that area seem to come from the DC modules - so maybe one of them is responsible for sensing the DC voltage in and send a signal back to the logic.
          After all the manual says that "Global AC Fail" will be triggered 5ms before the loss of regulation and that level of precision makes me think that maybe it's one of the DC modules (module 1?) responsible for determining that. Alternatively the logic can only probe the 390V DC and take a guess on when the DC modules are going to give up.
          • CapLeaker
            Leaking Member
            • 8344
            Find the optocoupler that is responsible for the ac power fail and go from there. Should be easy to find. It supposed to give 5ms warning of output regulation.
            • tony359
              • Oct 2018
              • 264
              • United Kingdom
              Indeed - the opto is the one with the green mark and I traced the signal to one output pin of the LM339. I know what the inputs are, I need to check what happens there.
              Because it says 5ms before "loss of regulation". I'd be tempted to think that this signal comes from the secondary and not primary. The main switching IC might have a feedback signal that goes back to the main logic and tell "I am about to drop the voltage".
              "simple" is a big word 🙂 Thanks for now!
              Edit by mod: Tony made a video about this fault now, seen here with timestamp to the relevant section: https://youtu.be/jDAyzrxcYdU?t=1609
                GLC65 GLM65 65 Watt Multiple Output Global Performance Switcher Datasheet
                65 Watt Multiple Output Global Performance Switchers
                Condor Part Summary
                • 65 Watt Wide Range Input
                • High Efficiency (Up to 90%)
                • Universal input 90-264 Vac
                • 2-year warranty
                • Also available in single outputs
                • Conducted EMI complies with FCC Class B and CISPR 22 Class B (Commercial models) and CISPR 11 Class B (Medical models)
                • Exempt from line harmonics standard EN61000-3-2
                • Commercial Approved to UL1950, CSA-C22.2 No. 950,
                • Medical Approved to UL2601-1, CSA 22.2 No. 601.1, and EN60601-1
                10-07-2024, 05:46 AM
              • FrancescoV
                Onkyo HT-R390 no sound output, video output ok
                by FrancescoV
                Good morning everyone,
                I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                The firmware reported is the following:
                M:1.00/11107BLP
                D:?.??/????????
                O:1.00/11107AL
                The DSP firmware given the question marks seems corrupt.
                On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                05-11-2025, 02:59 AM
              • benspawn02
                Anthem MRX500 - no sound. R2A15218FP issue??
                by benspawn02
                Dear Electronics Experts:
                I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
                08-12-2023, 04:46 AM
              • AstutePauciloquent
                Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                by AstutePauciloquent
                Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                11-23-2023, 11:02 PM
                NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                by sam_sam_sam
                I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                I bought this from an eBay seller but unfortunately they only had one
                I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                I bought three of from them to also make battery packs with this output power limit in mind
                I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                04-23-2025, 05:50 AM
