LG 39LN5400 no power
    • 12331
    • U.S.
    Re: LG 39LN5400 no power
    I wouldn't mess with the bga chip unless you have prior success with them and the proper equipment, best would be to get the right replacement board.
      • 12331
      • U.S.
      • unimatrix93
        • Oct 2021
        • 360
        • Magyarország
        Well yes, but the problem is I cannot find any proper replacement board for this TV, at least for a reasonable price.
        I think i will try to transfer the lvsd connector and the other components then. Its for the same tv, but for a 32inch, instead of the 39.
          • 12331
          • U.S.
          None on ebay? : There are individual eBay sites for Belgium, Denmark, Finland, France, Germany, Greece, Hungary, Ireland, Italy, the Netherlands, Norway, Poland, Portugal, Russia, Spain, Sweden, Switzerland, Turkey, and the UK.
          • unimatrix93
            • Oct 2021
            • 360
            • Magyarország
            I succesfully transfered the connector and the other components to the new mainboard.
            The TV is now turning on, backlight works but I have a black screen.
            I measured 12v, vgh 30 and lgv -8V on the TCON and when I disconnect the left/right side of the LCD they turn white according to the disconnected sides.
            What could be the problem?
            • dskall
              • Oct 2016
              • 2905
              • usa
              #26
              You could now have a software problem. Did you check closely for shorted/open connections? You might try probing the double lines on lvds for data going out of main. should get ~ 1.2v
              • unimatrix93
                • Oct 2021
                • 360
                • Magyarország
                #27
                I'm checking it right now, just have to turn over the TV.
                This is how the left side of the LCD looks like when I turn on the TV:
                https://1drv.ms/v/s!Ar4hHP2toEdog6Bs...F8eJw?e=3i1VFa
                • unimatrix93
                  • Oct 2021
                  • 360
                  • Magyarország
                  #28
                  Here are the values measured on the components top pins from left to right:
                  3.32V
                  3.36V
                  0.5V
                  1.02V
                  0.5V
                  1.06V
                  1.21V
                  0.5V
                  1.07V
                  1.92V
                  0.5V
                  1.02V
                  1.06V
                  0.5V
                  1.20V
                  1.06V
                  0.5V
                  1.20V
                  0V
                  3.6V
                  0V
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    #29
                    Looks like you have data coming out. Two different size screens is probably the problem.
                    • unimatrix93
                      • Oct 2021
                      • 360
                      • Magyarország
                      #30
                      What should I try then? Besides ordering another mainboard?
                      Which component determines what signals coming from the mainboard?
                      I have a IC programmer, I could try reprogram the SPI chip If it would help.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        #31
                        Not a firmware guy. I would say ic102. I think LOTAS is into the firmware part. I would message him.
                          • 12331
                          • U.S.
                          #32
                          do the alphanumeric digits on the white sticker of both mainboards match, I think 32 thru 47 should be ok if they match.
                            • 12331
                            • U.S.
                            #33
                            ok, I forgot you had a different mainboard, I'd say that's the problem, mismatch there, also bad leds right?
                            • unimatrix93
                              • Oct 2021
                              • 360
                              • Magyarország
                              #34
                              I fixed the backlight, which did not help. After that I narrowed it down to the main board as other guys suggested. The SOC is burned on the original mb so i ordered a new one which turned out to be for the same series of LGs just a smaller one.
                              I transferred the LSVD connector, so I transferred the lvsd connector and some caps and resistors to match the og board. Everything else is 100% same on the new mobo. ICs, markings, everything. I even checked if the vias are leading to the same points with a DMM and my microscope...
                              After that the TV turned on successfully but with black screen. Backlight works too. I couldn't find a short on the TCON/Riser either... I was thinking about transferring only the SOC but I never done BGA before and I'm afraid a screw it up
                              • lotas
                                • Jan 2016
                                • 4898
                                • Russia
                                #35
                                Compare these places and rearrange the resistors, as it was on the native board.
                                • lotas
                                  • Jan 2016
                                  • 4898
                                  • Russia
                                  #36
                                  But first, you should find out if your T-con is working (check the voltage at the test points), and there are no short circuits on the matrix bars, some T-cons can be driven into test mode.
                                  • unimatrix93
                                    • Oct 2021
                                    • 360
                                    • Magyarország
                                    #37
                                    I found a few differences:
                                    IC1903
                                    OG: HD38D
                                    NEW: HS40C
                                    Should I replace them?
                                    Also there is no resistor on R176 on the OG board.
                                    R226 is on R227 on the OG.
                                    The Tcon panel and the matrix should be okay, voltages were there and the I couldn't find any short either.
                                    • lotas
                                      • Jan 2016
                                      • 4898
                                      • Russia
                                      #38
                                      I don’t know about IC1903, I need to compare datasheets, what’s the difference. Look at the resistors where it should be, solder it where it should not be, then remove them.
                                      • lotas
                                        • Jan 2016
                                        • 4898
                                        • Russia
                                        #39
                                        T-CON has its own dc-dc converters for powering the matrix and they must match their rating.
                                        • unimatrix93
                                          • Oct 2021
                                          • 360
                                          • Magyarország
                                          #40
                                          I don't know about IC1903, I need to compare datasheets, what's the difference. Look at the resistors where it should be, solder it where it should not be, then remove them.
                                          I replaced the resistors, still no luck.
                                          I will transfer EEPROM and the SPI now.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • _AcE_
                                            JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
                                            by _AcE_
                                            I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
                                            There's no physical damage...
                                            08-10-2025, 09:27 AM
                                          • tony359
                                            Global AC logic output - XP Power FleXPower
                                            by tony359
                                            Hi all
                                            I've fixed a couple of FleXPower X7 power supplies. Since they have some logic outputs, I went to test them to make sure all was in order.
                                            "Fan Fail" would work when the fan is manually stopped.
                                            "Global DC" would change state when I manually adjusted one rail beyond 10%
                                            "Global AC" doesn't seem to do anything. To test, I power up the PSU and then I remove power. The 5VSB and Aux rails remain active for quite a few seconds after power is removed. I see the rails collapsing but there is no change in the "Global AC"...
                                            06-20-2025, 03:06 PM
