Philips LCD 42PFL5432D/37 - Bad PSU
  • philliesfan30m
    • Aug 2013
    • 542
    Re: Philips LCD 42PFL5432D/37 - Bad PSU
    but you replaced that 1 by the transformer i didn't see the pic you had attached.
    • PredictaTV
      • May 2013
      Oh yes, I replaced zd904 and 902also c958 with a 47uF @ 50v
      Got me bugged!!!! Have been swapping parts back and forth between TWO duplicate PSU's.
      • philliesfan30m
        • Aug 2013
        • 542
        did u check zd906?
        • philliesfan30m
          • Aug 2013
          • 542
          i have a philips 42pfl5432d/37 tv and just fixed mine which is the same board. mine made a hissing sound but mine was d912 that was causing it to do that after i replaced it then it was fine. i'd check zd906 and see what u get
          • PredictaTV
            • May 2013
            I put the parts on the other board, which was dead. It makes the rd lite come on, then if you push the red lite button on front of tv, the green on comes on. But no screen light. The "chirping is not on that board, though. What I guess I have to do is recheck ALL the diodes, transistors, again. Bed time now. Ill pick you all up tomorrow. THANKS so far.
            ROSS
            • kevinm34232
              • May 2012
              • 1884
              I had this model before, made noise when turned on, was 4 bad caps and ZD906.
              • hypnoangel
                • Sep 2013
                Hi All,
                New to the forum, but not forums. I am well versed in comp hardware, but not so much in TVS. I have the Phillips 42PFL5432D/37. Like others here, it started chirping and my screen went black The warranty is of course expired, so my DH put it in the room under the stairs. I started researching and found it was the power supply. I have confidence that I can replace either the caps or the whole unit. The problem is that this behemomth is lying face own on my counter (It is granite and 8' long by 4' wide, so while it is taking up a lot of room, it is not taking it all.) on top of a doubled blanket to protect the screen, and I cannot figure out how to get the back off. There are standard phillips heads screws holdingit on, but also some kind of screws that I have never seen before. They are not phillips, allen, star, or flat. Someone help me figure out how to get this danged thing apart, please? I cannot have it sitting there much longer. Frustration is becoming the norm with a TV that I had loved before the PSU went out. Thanks in advance,
                Angel
                • jetadm123
                  • 2169
                  #108
                  Possibly one of these? Photos of the screw head would help
                  • Globulus
                    • Sep 2013
                    • 20
                    • Denmark
                    #109
                    Originally posted by hypnoangel
                    Hi All,
                    Angel
                    I have a Philips 42PFL9603D. Not the same model. A year newer but the same brand.
                    I took the back off using just a T10 (Torx) screwdriver. Pretty common.
                    You might want to Google the chassis number to locate the service manual before you take it apart. Don't want to remove too many screws.
                    http://english.electronica-pt.com/el...p?find=TPM2.0U LA
                    Download link:
                    http://www.electronica-pt.com/index....tdown/id,7891/
                    Pictures at the beginning of the service manual show how to take it apart.
                    • budman67
                      • Dec 2011
                      • 7
                      #110
                      I just by luck had the flashing screen upon power up, and thought it was the ps caps again.....thing is that I fixed it for this nice older lady who cuts my hair....less than a year ago, and I thought......no way when I put in pannys instead of crapicon.......just for s**ts and grins....I took off the lid of the main digital, and OMG.....3 more crapicons.....split like the do........will replace here in a minute and let you know my findings.....no one is going to tell ssg Kelly that he cant fix it.......stay safe!!!
                      • thomasw
                        • Nov 2015
                        • Norway
                        #111
                        I just picked up an 42PFL9603D(/10) from a buddy that said it didnt turn on and didnt want to spend time fixing it.
                        I'm not very technically inclined, but I can something and want to learn more. I have turned away back cover and started troubleshooting. Can not see any obvious errors, but I have discovered a few things.
                        There is a buzzing sound when I plug the power cord in, not very high but just so you can hear it.
                        There are NO signs of life in the standby LED. Completely dead.
                        If I remove the cable that goes from "standby led board" to the motherboard, illuminates a green LED on the back (of the motherboard). If I plug that cable back again, the same green LED turns off again.
                        Is it bad caps as many suggest, or do I have to troubleshoot some more first? Could someone please point out which ones I have to replace?
                        I dont have a multimeter by hand right now, and if you guys mean its something else than bad caps that causes this error, I will just trash it..
                        • thomasw
                          • Nov 2015
                          • Norway
                          #112
                          Forgot to insert the pictures of psu and motherboard
                          • Shane711
                            • Dec 2014
                            • 493
                            I have this TV Philips 42PFL5432D/37 and someone had worked on it before me so they kinda messed it all for me. I am having a problem with the power supply. It is doing that chirping and I can not get it to stop. Does anyone know the proper values for ZD902, 904, 906, 908? I found a P6KE120A and a P6KE350A removed from the board and seems they were missing from ZD902 & 904 but the diagram I found says both ZD902 & 904 are P6KE120A. I found a P4KE250A in ZD906 and I assume that is correct. Cap 947 was reading 2uf instead of 6.8uf so I changed that but I still have the chirping. Power supply board is 715T2432-2. Thank you
                            • cccamgeek
                              • May 2009
                              • 13
                              #114
                              Drear sirs
                              can aby one help for a eeprom dump for this tv please :
                              PHILIPS 42PFL9603D/10
                              best tegds
                              • ahmedtou
                                HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                by ahmedtou
                                help me please
                                I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                I will share all the details with you, including the disc information.
                                Code:
                                HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                Current Profile: BD-R
                                Disc Information:
                                Status: Empty
                                State of Last Session: Empty
                                Erasable: No
                                Free Sectors: 12,219,392
                                Free Space: 25,025,314,816 bytes
                                Free Time: 2715:27:17 (MM:SS:FF)
                                Next
                                08-27-2025, 08:49 AM
                              • Sharpa
                                Repair attempt Philips 55OLED804/12
                                by Sharpa
                                I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                The symptoms when bought: Philips logo appears then tv turns off
                                Things tried so far:
                                1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                Today, 08:30 AM
                              • alro7779
                                Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                by alro7779
                                Hello, guys!
                                The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                09-14-2025, 12:25 AM
                              • G33RT
                                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                by G33RT
                                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                It does power up when pressing the power button.
                                I already try the power button while plugin the plug with no result.
                                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                Could this be an PSU or eMMC issue ?
                                07-19-2025, 03:43 AM
                              • Ifixstuff9
                                Philips 42PFL5432D/37 power supply issue no 12v
                                by Ifixstuff9
                                I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
                                After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
                                05-02-2021, 09:29 PM
