Re: Philips LCD 42PFL5432D/37 - Bad PSU
Perfect! I got IC907 down as TEA1507P (this is the PWM controller for the standby circuit).
Now the only thing I couldn't read from the schematic is the output voltages. It looks like it says 21 volts for the top and 12 volts for the bottom one - these voltage are all the way on the right on the schematic. Please verify that the values I read are correct.
So, it looks like the external standby PSU mod will work. Just need to get the value of the standby voltage, remove a few jumpers, wire the external PSU, and it will be good to go.
As for trying to fix the PSU by reusing a transformer from another PSU, it probably won't be possible, unfortunately. The old transformer has 2 auxiliary windings while most computer PSUs only have 1. Save the old transformer in your junk box, though, just in case you run into another transformer with a similar core.
