Sharp LC80UH30U Vertical Band
  • AJ2021
    • Jan 2022
    • 4
    I just moved to a new apartment and now I got a vertical band on my tv. The band is changing colors all the time. Is there a fix for this? If someone has had the same problem and fixed it I would really appreciate the help as I am retired and on a fixed income and cannot afford a new tv.
    I can change any boards and bad caps but I'm not good with a volt meter.
    Thank you very much for any assistance.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sharp LC80UH30U Vertical Band
    I would say you are screwed. Looks like a panel problem.
    • Diah
      • Feb 2013
      • 6396
      its look one ribbon cable in case you didnt hit it by transport..., at the same area seated again carefully
      • AJ2021
        • Jan 2022
        • 4
        Thanks for you reply. I was hoping for a little less than a single gun salute and burial at sea! Any other opinions?
        • dskall
          • Oct 2016
          • 2905
          • usa
          You could put pressure on that tab and possibly make it work.
            • 12206
            • U.S.
            I second that, grab the bezel right on that faulty area and give it a squeeze, bezel not the screen.
            • AJ2021
              • Jan 2022
              • 4
              First I would like to thank all the badcappers that answered my post.
              I finally had some time to take the back off the set and did an inspection for bad caps took off all the connections and reseated them. Also disconnect the tcon board one side at a time. Nothing solved the vertical line problem.
              I also tried to squeeze the bezel I even took a rubber mallet and hit it a few times.
              I guess that "DSKALL" was correct in his thinking in his original reply
              Thanks again it is always worth a try. So now I will chalk it up as one of the great unsolved mysteries!
              • neilc6
                • Nov 2015
                • 1550
                The vertical band will correspond to one of the the orange flex cables connected to the thin panel boards. There is either a bad connection or a bad chip on film (COF) embedded on the flex. Considered a bad panel and not repairable.
                • howardc64
                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                  by howardc64
                  Failure Symptom
                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                  Where is the short?
                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                  05-27-2025, 02:56 PM
                • otaku_nut
                  Vizio E701i-A3 fixed but now has red vertical line
                  by otaku_nut
                  Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                  Yesterday, 06:11 PM
                • ninja_zx11
                  Sharp LC-70LE650U vertical black and red bars
                  by ninja_zx11
                  70" LED TV is Sharp LC-70LE650U.
                  Initial problem was horizontal lines and slow motion lurrs on the bottom left of the screen. So I removed both the left and right ribbon cables from the T-con board and tried to clean it with alcohol and when I put it back, this issue appeared. I tried carefully reinserting the ribbon bon cables but same thing. I checked the traces of the ribbon cables with magnifying glass and everything looks good. I cleaned the small jumper ribbon cable on the left side of the screen which cured the horizontal line and slow motion blurs...
                  07-07-2023, 11:27 PM
                • valvashon
                  Sharp LC19SB24U; red vertical line comes and goes
                  by valvashon
                  Yes, this is a very old Sharp 19" but I would like to fix it if possible. As you can see from the attached picture there is a single red vertical line.
                  Yesterday when I turned the set on, it was there for about 30 minutes then disappeared and did not show up again (set was on for another 3 hours or so).
                  Today it was not there when I powered the set on, then appeared after about 15 minutes. Set has been on for about an hour and it's still there.
                  From what I have read I'm guessing that this might be the t-con board and not the display itself as it does come and go.
                  02-03-2023, 10:02 AM
                • ajshoe
                  samsung pn51e7000ff vertical band
                  by ajshoe
                  just got a samsung plasma (3d version) that has a vertical band on right side. Has a great picture except for the vertical band. Haven't opened it yet. Is this a bad panel ?...
                  03-14-2021, 06:54 PM
