NEVIR NVR-7402-40HD-N no standy by light
  • mi16rs
    • Jul 2015
    • 43
    • Portugal
    Hi
    i have a NEVIR NVR-7402-40HD-N whit powersuply board CQC13001103908
    the tv as no stanby light and wont turn on , i find a Diode faulty and replace it but still the same , i dont have any electric schem for it , could some one help me whit this ?
    • 12272
    • U.S.
    Re: NEVIR NVR-7402-40HD-N no standy by light
    Test the powerboard to see where you stand, video demo there: https://www.youtube.com/watch?v=XH9GfkGQX1I
      • 12272
      • U.S.
      Some straight on focused pictures of the whole back and of each board would help a lot.
      • mi16rs
        • Jul 2015
        • 43
        • Portugal
        Hi
        Sorry for the late reply , in attachments are the pictures off the board
        the diods mark in red one of theme was faulty so i replace it but still not work
        i have meseured the voltage on the white conectors and it as no power so the problem on power suply but im not able to manage were the problem is , the main fuse is ok .
        please could some one help me on this ??
          • 12272
          • U.S.
          It usually starts with powerboard testing, you have a multimeter? did you look at the video I linked? here's another: https://www.youtube.com/watch?v=4v8DcqCNG4A
          • mi16rs
            • Jul 2015
            • 43
            • Portugal
            Yes i have measure the voltages on the white conectro that goes to the logic board and i dont have any voltage on it
              • 12272
              • U.S.
              Ok, unplug everything all connectors from the powerboard, plug power cord back into powerboard, see if you have the standby voltage.
              • mi16rs
                • Jul 2015
                • 43
                • Portugal
                i did that already and still no standby voltage
                  • 12272
                  • U.S.
                  Picture of powerboard isn't very clear, need standby voltage or nothing's going to work, simple things first, test power cord for continuity, make sure fuse on powerboard is ok, if ok, maybe move on to check bridge rectifier.
                    • 12272
                    • U.S.
                    https://www.google.com/search?client...rB7gLLy6TwCw18
                      • 12272
                      • U.S.
                      Check all diodes and resistors, at least the bigger ones, the tiny ones are a pain to deal with and should make sure that it is a tiny one at fault before messing with those. If any test odd, take out of circuit and test again, can search for resistor color charts if needed.
                      • mi16rs
                        • Jul 2015
                        • 43
                        • Portugal
                        Yes i have done that and its all ok , this board as a ac/dc converter LNK7666E but i dont know how to check if this is ok or this is the one its faulty .
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          Originally posted by mi16rs
                          Hi
                          Can't zoom on picture. Center white connector is 12v? What voltage do you have on main capacitor? Your mosfet on aluminum heatsink has a diode that is connected to drain of your mosfet. What is voltage across that diode?
                          • mi16rs
                            • Jul 2015
                            • 43
                            • Portugal
                            only the blue mark conector as the stanby cable on , the red ones does not have anything conected , as for the main capacitor voltage this is a 100uf400v and i read 300v
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              Does white connector in center of board say power upgrade? Your pictures aren't good enough to see.
                              • mi16rs
                                • Jul 2015
                                • 43
                                • Portugal
                                its not a mosfet its a LNK7666E ac/dc converter
                                • mi16rs
                                  • Jul 2015
                                  • 43
                                  • Portugal
                                  see iff helps
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    Looks like diode next to switching controller. What is voltage across it?
                                    • mi16rs
                                      • Jul 2015
                                      • 43
                                      • Portugal
                                      do you mean the one is mark in red??? puting the multimeter on it in DC does not show any voltage
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        If one end is connected to last pin on controller and measuring across diode shows no voltage, then I would say you have bad controller.
                                        • JohnML1975
                                          Soniq QSL422XTV2 - not standy light and will not turn on
                                          by JohnML1975
                                          Hello All
                                          Have this TV and just started working on it
                                          Removed back panel and cannot see obvious problem
                                          Used thermal camera and the boards appear to not have power going to them
                                          Discon M/B to PSU and fault did not change
                                          Did same with T-CON board and fault did not change
                                          Next I will check if there is power going to the T-CON and the LCD inverter boards and the Main Board M/B
                                          Thank you
                                          09-06-2025, 06:23 PM
                                        • learnmore
                                          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                          by learnmore
                                          Hello Community!
                                          CASE DETAILS
                                          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                          Tried inserting firmware on USB and left it in for a few hours, but no change
                                          03-03-2024, 09:49 AM
                                          Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                          by sam_sam_sam
                                          I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                          I also have back when Light of America had these light bulbs available for yard lights
                                          The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                          While the Lithonia lighting fixture has all most certain bulb failure
                                          So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                          I have only had this light fixture for not more than a year if it...
                                          07-02-2023, 03:45 PM
                                          LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
                                          LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 09:10 PM
