Soniq QSL422XTV2 - not standy light and will not turn on
  • JohnML1975
    • Jul 2025
    • 64
    Hello All
    Have this TV and just started working on it
    Removed back panel and cannot see obvious problem
    Used thermal camera and the boards appear to not have power going to them
    Discon M/B to PSU and fault did not change
    Did same with T-CON board and fault did not change
    Next I will check if there is power going to the T-CON and the LCD inverter boards and the Main Board M/B
    Thank you
  • JohnML1975
    • Jul 2025
    • 64
    Uploaded some photos
    I have no power to the fuses on the T con and no power to the fuses on the inverter board
    from the PSU to the mainboard I only have 5.1 V as STBY voltage where it says STB
    No other voltages on that connecter are present
    I did lazy check on the mother board at some of the inductors and found no power
    i am going to remove the PSU and have a clean of it and have a look as well
    Thank you
    • JohnML1975
      • Jul 2025
      • 64
      Update
      The TV works, it turns on and the back light works
      There is power button under the TV which needs to be on
      Then use remote or standy button on side of TV to turn it on
      However, when I test the the TV using HDMI the picture seems to connect then drop out
      It says either no signal or not supported
      So I still need to solve the HDMI problem
      • JohnML1975
        • Jul 2025
        • 64
        Looked at HDMI ports and chip and surrounding capacitors
        Cannot really see anything
        Ran sharp spike along HDMI port legs and they all seem secure
        Checked for shorts on all the SMD capacitors and cannot see anything
        Might try connect HDMI and then use thermal camera to see if anything shows uo
        • R_J
          • Jun 2012
          • 9608
          Your HDMI source could be sending an unsupported resolution to the tv, change the output on the source device to something the tv supports.
          • lotas
            • Jan 2016
            • 4802
            • Russia
            Yes, that's a good point, switch the source to HD Ready resolution (1366 x 768).
            • sigmeyer
              • Feb 2020
              • 158
              • Serbia
              And what about other HDMI ports , do they also drop out? If its not a port issue , than do what they say above , and also try different cable...
              • JohnML1975
                • Jul 2025
                • 64
                Hello and thank you all for your ideas and suggestions
                I did try the other ports and I felt they were not good either
                They dropped out while watching and if i wiggle the HDMI cable they drop out easily
                However I did not try to adjust the output settings and this i will try
                Again thank you all
                • lotas
                  • Jan 2016
                  • 4802
                  • Russia
                  So maybe you need to replace the HDMI cable with a new one.
                  • Adogabriel100
                    Macbook pro A1278 820-2936 No light/turn on
                    by Adogabriel100
                    Hey! how are you guys? i wonder if you could help me with this macbook 820-2936 that does not turn on. (Doesn't have green/orange light).
                    History:
                    this macbook came for a short on C6990 that blows D6990 and R6990 on his way. i re-placed the componets and it work again.
                    A month later comes back again and has the actual problem (no green/orange light and dont turn on)
                    The macbook can turn on with only the battery connected but in fact, dosent charge.
                    Voltajes:
                    PP3V42_G3H = 3.3v
                    PPBUS_G3H = 12.2V
                    PM_PWRBTN_L...
                    06-28-2023, 07:41 PM
                  • dionzarek
                    PS5 Slim EDM-040 Only turn on 1 Sec, Blue light then immediate off.
                    by dionzarek
                    Hello everyone, I am new to this PS5 troubleshooting, I need help on diagnosing the problem. My PS5 Slim board EDM-040 that beep and only shows blue light then immediately turn off.
                    I've checked the PSU its normal 12V. I've checked all the capacitors its all good no shorts, but there are 2 caps shorted, I think its near the SSD. You can look at the image attachment.
                    When tested it only shows 0.003 while other caps show 0.4 to 1. WHen in continuity mode those 2 caps goes beep/shorted.
                    Any help to where should I check on or suggestion would be very appreciated....
                    02-08-2025, 11:00 PM
                  • vdrokko99
                    MBP wont turn on Only green light on charger
                    by vdrokko99
                    I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
                    SMBUS_SMC_BSA_SCL 3.5V
                    SMBUS_SMC_BSA_SDA 3.5V
                    12-01-2024, 12:18 PM
                  • jorpec
                    Qilive Q40FS21 after turn on revert to standy
                    by jorpec
                    I have this lcd tv after i turn it on, the Qilive logo appears on the screen then 2 seconds later revert to standby, first i thought it could be the led bars, if i disconnect the backlight the tv stays on, or if i leave the led bars connected but disconnect the screen the backlight stays on, then i power the backlight though a led tester i was able to see that the tv was working, then i go to menu and lower the backlight intensity to 10(from the min 0 to max 100) then connected the backlight again and the tv worked normally but when on the menu i raise the backlight intensity when reaching 64...
                    06-19-2025, 08:29 AM
                  • ruletero
                    HP Omen only do not turn on, only flashes white light
                    by ruletero
                    Hi everyone
                    Please help me with this laptop
                    HP Omen 15-dc0003la , MB DAG3DBMB8D0 REV. D
                    It doesn't turn on, when I connect the charger with battery orange light appears on power jack and without battery white light appear, it is fine I think
                    But if I press power button, power led flashes white once, only that, not consumes anything power, not start, nothing more.
                    Bios was programmed with a working version, no changes.
                    Voltages
                    +3vS5 = 3v when I connect charger, next goes to 0 (I think is fine)...
                    06-07-2023, 10:11 AM
