LG55UB850V no picture or audio - flashing LED's help please?
  • nomoresonys
    • 12323
    • U.S.
    #181
    I set mine about 60 percent, makes them last much longer.
    • Green Probe
      Recapping a Denon AVR X6400h SMPS
      by Green Probe
      (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
      Disclaimer: I'm an amateur hobbyist and will get things wrong.
      Always use caution when working around mains power and high voltage capacitors!
      Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
      SYMPTOMS:
      -No display...
      07-18-2025, 03:36 PM
    • STKR123
      Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
      by STKR123
      As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
      I wonder if re-flashing the BIOS might be of any use here.
      As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
      There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
      11-03-2024, 06:58 AM
    • rabbituk
      Sony HCD BX7700dbi CMT flashing standby
      by rabbituk
      I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
      So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
      02-11-2025, 05:05 PM
      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
      I am comparing them to a brand new one that I installed
      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
      I going to let it run for several days before I remount back on the wall next to the...
      09-05-2024, 06:48 PM
    • Bloopeta
      Samsung UE43KU6400U Flashing Red Standby Light
      by Bloopeta
      Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
      Power button does nothing
      Have unplugged the mainboard, and backlights illuminate.
      Have tried removing panel ribbon cables one at a time, and that makes no change.
      With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
      Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
      09-11-2023, 02:34 AM
