Vizio TV E470VL SMPS Flucuation Output Voltage
  • dholley
    Mr. Blinky
    • Jan 2022
    • 87
    Re: Vizio TV E470VL SMPS Flucuation Output Voltage
    In the attached picture these two MOSFETS, voltages seems weird, is it normal that when I measure in DC VOLTS at the drain, voltage starts out as high as 27 volts and lowers down to 9 volts?
      • 12317
      • U.S.
      #142
      Are you using the neg. side of bridge rectifier or neg. leg of main filter cap for ground? either is ok when checking voltages in the hot side, use caution HIGH voltage on hot side.
      • dholley
        Mr. Blinky
        • Jan 2022
        • 87
        Negative side of big cap
          • 12317
          • U.S.
          #144
          Not sure what we've covered, you do have around 160v on the big caps when in standby? powered up it should go up to around 390v.
            • 12317
            • U.S.
            #145
            Do you have a steady standby voltage or is it still 0?
              • 12317
              • U.S.
              #146
              Did you test the new zener diode before replacement?
                • 12317
                • U.S.
                #147
                not sure, maybe test Q101 and 131, and test every resistor in that area, the values should all be marked see the tiny writing, make sure the ohms reading is close to the value marked on the resistor.
                • dholley
                  Mr. Blinky
                  • Jan 2022
                  • 87
                  Yes
                  • dholley
                    Mr. Blinky
                    • Jan 2022
                    • 87
                    167 volts on the filter caps
                    • dholley
                      Mr. Blinky
                      • Jan 2022
                      • 87
                      No standby voltage, no output voltage of any kind
                      • dholley
                        Mr. Blinky
                        • Jan 2022
                        • 87
                        Any ideas why there is changing voltages on these mosfets? The mosfets just above them are steady and stable at 167 volts
                        • dholley
                          Mr. Blinky
                          • Jan 2022
                          • 87
                          How do test Q101 and 131 in circuit with a multimeter?
                            • 12317
                            • U.S.
                            #153
                            yeah, i guess, see if its short, i believe you test drain to gate and drain to source, might be middle leg to each outer leg if continued beep or close to 000 in diode mode its probably shorted. Dont get it confused with both outer legs because they can show continuity and be ok. Prolly best practice is get the datasheet of the component to be sure of the pinouts.
                            • dholley
                              Mr. Blinky
                              • Jan 2022
                              • 87
                              There is only 1 volt at Q707 at the drain. Picture attached. For orientation it is right next to big filter cap, cap farthest away from input power. Any suggestions?
                                • 12317
                                • U.S.
                                #155
                                make sure resistor R704 is ok, it looks beat up from the picture.
                                • dholley
                                  Mr. Blinky
                                  • Jan 2022
                                  • 87
                                  I wanted to thank everyone for their help in trying to fix this power supply. I was not available to fix it an ended up buying replacement at BuyQual.com at a reasonable price.
                                  thank you and God's Blessings,
                                  Danny
                                    • 12317
                                    • U.S.
                                    #157
                                    well we gave it our best shot, thanks for update, it would probably be a lot easier to determine what's wrong with it now that you have a working board to compare with, thanks for the blessing, right back at ya.
                                    • electron_jj
                                      Panasonic TH-L42D25A checking the PSU output voltage
                                      by electron_jj
                                      Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                      I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                      08-29-2021, 08:13 AM
                                    • David Miteff
                                      NM-D521 rev. 2.0 output voltage on CPU coils seemingly low
                                      by David Miteff
                                      Hello, guys!
                                      As the title says - the board is NM-D521, on the input of the CPU coils I read 1.2-1.3V, which should be normal, but on the output I read around 0.6-0.8V. The laptop bootloops with no picture.
                                      As of right now I don't have a thermal camera, so I can't confirm a shorted or partially shorted CPU chip. Do you have any other suggestions as of why the output voltage might drop like that?...
                                      12-30-2024, 07:02 AM
                                      MT3608 Step-Up Converter IC Datasheet
                                      The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                                      Internal soft-start results in small inrush current and extends battery life.
                                      The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                                      10-07-2024, 05:02 AM
                                    • Ri5ux
                                      Playstation 5 2 Second BLOD, F3501 Voltage Output Question
                                      by Ri5ux
                                      Hi there, just wondering if anyone out there who has a semi-working or working PS5 board could check the output voltage on F3501's buck converter for me, with and without power. I have 12V on the input, fuse not blown, no output voltage on that IC, with or without power, and no shorts present.
                                      Symptom: 2 Second BLOD
                                      Testing: All other rails seem present. APU, SSD, South Bridge, and RAM confirmed to be powering up using a thermal camera. Monitoring the current draw of the 12v rail shows a somewhat normal boot cycle of the south bridge. Jumps up to 300ma, and down to 0....
                                      09-09-2023, 06:57 PM
