LG 55EG960v service menu
  • chopper00
    • Jan 2012
    • 60
    Hi
    Can someone please provide a link to the service menu IR wav file for above TV
  • chopper00
    • Jan 2012
    • 60
    Re: LG 55EG960v service menu
    I am looking to remove the protection mode on the mainboard
    • Diah
      • Feb 2013
      • 6558
      service menu In_Start or the AZ_ADJ had nothings to do with what you want to do.. so you cant..
      • yokoono
        • Apr 2010
        • 511
        Look:
        • chopper00
          • Jan 2012
          • 60
          Originally posted by yokoono
          Look:
          Thanks, is this the file I need to remove protection mode?
          • Diah
            • Feb 2013
            • 6558
            power_only,wave file to by pass the protection.. not to remove.
            • chopper00
              • Jan 2012
              • 60
              Thanks, much appreciated.
              • chopper00
                • Jan 2012
                • 60
                Is this IR lead correct to use?
                https://www.ebay.co.uk/itm/baolongki...-127635-2958-0
                • Diah
                  • Feb 2013
                  • 6558
                  buy LG service remote control better than this.. its cheap
                  • chopper00
                    • Jan 2012
                    • 60
                    This one ok?
                    https://www.ebay.co.uk/itm/RM-Series...-127635-2958-0
                    • Diah
                      • Feb 2013
                      • 6558
                      i cant review. better one user from uk answer you as they most all bought one.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4536
                        • Italy - Milan
                        i have used an in-start wav file from other site and after input 0413, so the instart menu appears, but it is not possible to change for example Area option or other settings, do you know how to solve this? Also ez-adjust same limits.. thanks
                        PS: these files are different and them works! thanks..
                          LCD LED TV Service Menu Codes
                          ALL LCD LED TV SERVICE MENU CODES
                          Service Menu Code with Board Name
                          China Universal Board / Jumper Board Service Menu Code
                          Changhong Ruba Service Menu Code
                          Ecostar LED TV Service Menu Code
                          Orient LED TV Service Menu Code
                          Haier LED TV Service Menu Code
                          TCL LED TV Service Menu Code
                          Samsung LED TV Service Menu Code
                          LG LED TV Service Menu Code
                          Videocon LED TV Service Menu Code
                          Supra LED TV Service Menu Code
                          Toshiba LED TV Service Menu Code
                          Symphony LED TV Service Menu Code
                          Veste/ LED TV Service Menu Code...
                          10-31-2024, 03:58 AM
                        • Robby-Gr
                          TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                          by Robby-Gr
                          I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                          However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                          The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                          Additional issues:...
                          09-27-2025, 12:02 AM
                        • intercepter
                          JVC LT-32CA120 service menu
                          by intercepter
                          I have JVC LT-32CA120
                          Board:Vestel 17MB171
                          I need rotate screen.It is possible in service menu and how to enter service menu?
                          Thanks.
                          12-10-2024, 10:29 AM
                        • alltvrepairs
                          Jvc Lt-65VU3000 reduce backlight from service menu
                          by alltvrepairs
                          I have just replaced led set of this vestel tv due to age.
                          I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
                          Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
                          Thanks again....
                          09-20-2025, 05:03 AM
                        • sohail5307
                          I need how to open this Dell service menu option in dell latitude e6420
                          by sohail5307
                          I need to open service menu of Dell laptops like image in attachment
                          Ignore my English
                          I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
                          01-13-2023, 05:56 AM
