Sony xbr65x900c sound yes, no backlight or image.
  • diif
    • Feb 2014
    • 6978
    • England
    #341
    Re: Sony xbr65x900c sound yes, no backlight or image.
    Maybe I'll use difs reflow profile, I hear he's never had a return on ANY of his reflows.
    It's diif, and you read not heard about the quality of my reflow work. I'm flattered you've been thinking about me though.
    • nomoresonys
      • 12332
      • U.S.
      #342
      Right, sure DID NOT hear about it, as nobody ever verified it, AND wasn't thinking about you at all, til I read what you think about Mr. Trump. I had no idea that you are qualified to JUDGE Mr. Trumps integrity AND such an authority on the subject of AMERICAN politics. AND I don't give a flying f#%K what your name is. YOU are one of the very few people here that I NEVER could stand, period, exclamation mark. As much as I'd like to, I won't be responding to any more of your little remarks, It's against the rules AND a waste of my time. Don't know how you got off the ignore list in the first place.
      • diif
        • Feb 2014
        • 6978
        • England
        #343
        If it hadn't been for your pissy comment and getting my user name wrong, I wouldn't have commented. The poor attitude is yours not mine, I'm glad you won't be commenting further though.
        • nomoresonys
          • 12332
          • U.S.
          #344
          Moderators can you do something about this HARASSMENT?
          • nomoresonys
            • 12332
            • U.S.
            #345
            Thanks Unspun for replying on the other xbr thread, no I wasn't getting 12 to the tcon, Diah helped me bypass to get signal from powerboard to tcon, then there was 12 v at tcon fuse, so I guess tcon on is one of the signals that the mainboard isn't sending. It may be because I can't seem to update it properly for some reason.
            • nomoresonys
              • 12332
              • U.S.
              #346
              Now I think I killed the mainboard, put the tiny parts back on, they seem to measure the same as they did before I took them off. But I heated the 9 memory chips around the sonyx1 and the x-reality pro chips to about 440 f, put the board back in, now tv is dead, I just hope I didn't kill the mainboard because I couldn't figure out how to do the firmware update/pair or because the dl board was bad.
              • german_20ar
                german_20ar
                • Jan 2020
                • Argentina
                #347
                Hello, I have a Sony xbr-65x900c + It turns off and flashes 4 times red light sometimes it turns off after 30 seconds sometimes it takes 3 minutes it's relative! Can you help me, please! Thank you very much
                Hola, Tengo un Sony xbr-65x900c + Se apaga y parpadea 4 veces luz roja a veces se apaga a los 30 segundos a veces demora 3 minutos es relativo! Me pueden ayudar por favor! Muchas Gracias
                • nomoresonys
                  • 12332
                  • U.S.
                  #348
                  There's a pretty easy test you can do to determine if it's a backlight issue, I would NOT play a tv for normal use with this bypass because it could burn everything down, because it bypasses a safety feature and they're there for a good reason, just look on youtube for xbr65x900c 4 blink fix, BUT I don't call it a fix, just a way to troubleshoot, there's a few of them they involve grounding the bl_error wire.
                  • domix
                    Sony KD - 65XF9005 - No image, sound OK
                    by domix
                    at tv KD - 65XF9005 i have a problem.
                    Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                    is this a common problem for this tv?
                    i attached pictures of inside. Supply board looks okey, no blowed caps....
                    07-21-2025, 06:37 AM
                  • rimwall
                    Sony KD-65x7500D - double image - Tcon or Panel?
                    by rimwall
                    This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                    I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                    11-18-2025, 02:09 AM
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
                  • shahnld
                    Sony kdl 65xg9505 green amber blinking
                    by shahnld
                    Good Day.
                    I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                    i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                    green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                    01-03-2024, 03:05 PM
                  • alegatorul
                    sony bravia kdl-43w756c, no power, no sound
                    by alegatorul
                    the charger brick has 19,2-19,3 vcc
                    changed the inverter board same result.
                    where should i start?
                    cheers
                    11-15-2025, 10:00 AM
