Sony xbr65x900c sound yes, no backlight or image.
  • Diah
    • Feb 2013
    • 6613
    Re: Sony xbr65x900c sound yes, no backlight or image.
    MAN.. yours TV now after you replace PCB turn on and you hear start music... why you are talking on 4 blinking which you don't have... and whome this fuck people grounded error to GND.. then why there are ICs monitoring the fault.. this absolute wrong and kids play.
    • nomoresonys
      • 12323
      • U.S.
      #262
      put it back to original, did get 12 on pin 1 of ld board, still only .10 volts on tcon 5 pin connector and tcon fuse.
      • nomoresonys
        • 12323
        • U.S.
        #263
        damn man, theres 40 youtube videos of people "fixing" their tv in just that way, im not making it up.
        • Diah
          • Feb 2013
          • 6613
          T-CON 5 pin socket get the 12.V direct from PCB.. you see now how the game are.. you may toasted your replacments PCB and i warrned you about it before..#
          edit. disconnect the sockts on t-con side and messure the other side if you have 12v at start up keep yours eyes on DMM
          • nomoresonys
            • 12323
            • U.S.
            #265
            anyhow its the same except the 12 at 1 pin of ld board is there, the tcon isnt getting 12 and backlights are out.
            • nomoresonys
              • 12323
              • U.S.
              #266
              no, its ok, all voltages are there, its not the powerboard.
              • nomoresonys
                • 12323
                • U.S.
                #267
                its backlights ld or mainboard.
                • nomoresonys
                  • 12323
                  • U.S.
                  #268
                  checking for voltage on 18 again.
                  • Diah
                    • Feb 2013
                    • 6613
                    fu°°K all 40.... this electronic not kids game... by pass yes we have... but later what will happen yours favorite youtube will not show you.
                    • nomoresonys
                      • 12323
                      • U.S.
                      #270
                      18 is still 0v.
                      • nomoresonys
                        • 12323
                        • U.S.
                        #271
                        I wouldnt leave a tv bypassed like that, was just for testing BUT it didnt work for me but worked for many.
                        • nomoresonys
                          • 12323
                          • U.S.
                          #272
                          im trying to fix this damn sony the right way, but i dont know what the hell is wrong with it.
                          • Diah
                            • Feb 2013
                            • 6613
                            report back you hear music and no by pass at all every things original as it should...
                            1- t-con fuse 12V ?
                            2. pin 1 LD 12V ?
                            3. LVDS scoket to t_COn you have 2 one 41 pins and other 51 pins. the one of 51 bin the last pins 44 & 45 got 12v 47 to 51 got 12V. ? all these pins related to signal about BL ready or on or dim.
                            • nomoresonys
                              • 12323
                              • U.S.
                              #274
                              1- t-con fuse 12V ? NO 2. pin 1 LD 12V ? YES 3. LVDS scoket to t_COn you have 2 one 41 pins and other 51 pins. the one of 51 bin the last pins 44 & 45 got 12v 47 to 51 got 12V. ? NO just fractional like the fuse .10 volts. thats with cables in place.
                              • nomoresonys
                                • 12323
                                • U.S.
                                #275
                                NOT going to that orgy, those people were UGGGGGLY.
                                • Diah
                                  • Feb 2013
                                  • 6613
                                  yours bypass which you keep it toasted one or more boards,,, yesterday was better things but today as now for me over net i will never never understand the fault. sorry.
                                  • nomoresonys
                                    • 12323
                                    • U.S.
                                    #277
                                    its the same as it was yesterday and before i blew up the other powerboard, you said if no voltage on 18 of ic 9107 then replace ic correct? so probably the ic is bad right?
                                    • nomoresonys
                                      • 12323
                                      • U.S.
                                      #278
                                      been trying to fix this for a while now, read a whole lot of shit, some fixed it with a new main some fixed it with an update, some fixed with new backlights, did not see any other fixes.
                                      • nomoresonys
                                        • 12323
                                        • U.S.
                                        #279
                                        well anyway thanks for trying, I know it was a big effort and I appreciate it.
                                        • nomoresonys
                                          • 12323
                                          • U.S.
                                          #280
                                          This is the IC on mainboard without voltage on pin 18, which is RA1ICSPCLK: https://pdf1.alldatasheet.com/datash...16F527_12.html
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
