Technika 40-E271 menu not responding
  • stav242
    • Jan 2014
    • 61
    • United Kingdom
    Hi
    See attached.
    Powers on and TV repsonds to remote buttons - but just recently the menu has stopped displaying. Only this grey box moving round the screen.
    Tried the firmware flash files on eeprom thread but can't see what's happening.. if anything.
    Tried factory reset remote proceedure, but again TV seems to respond but can't see anything happening.
    Any ideas?
  • lotas
    • Jan 2016
    • 4458
    • Russia
    Re: Technika 40-E271 menu not responding
    Try to reprogram Flash: W25Q32BVSIG through the programmer, if you need a dump, I'll post it here.
    • stav242
      • Jan 2014
      • 61
      • United Kingdom
      hi, yes please. that would save me some time. thanks.
      • lotas
        • Jan 2016
        • 4458
        • Russia
        Try Dump, write to new spi flash.
        • vinceroger69
          • Mar 2012
          • 6714
          This thread also has a firmware link if needed
          https://www.badcaps.net/forum/showth...ht=tcon+eeprom
          • lotas
            • Jan 2016
            • 4458
            • Russia
            It turns out that this TV has two different motherboards "T.MSD 306 69A 12023" and "TP.MSD309.BP86"
            • jimbofz
              • Apr 2013
              • 537
              beat me to it vinceroger,
              just about to point him to my earlier post ,
              good man
                LCD LED TV Service Menu Codes
                ALL LCD LED TV SERVICE MENU CODES
                Service Menu Code with Board Name
                China Universal Board / Jumper Board Service Menu Code
                Changhong Ruba Service Menu Code
                Ecostar LED TV Service Menu Code
                Orient LED TV Service Menu Code
                Haier LED TV Service Menu Code
                TCL LED TV Service Menu Code
                Samsung LED TV Service Menu Code
                LG LED TV Service Menu Code
                Videocon LED TV Service Menu Code
                Supra LED TV Service Menu Code
                Toshiba LED TV Service Menu Code
                Symphony LED TV Service Menu Code
                Veste/ LED TV Service Menu Code...
                10-31-2024, 03:58 AM
              • Retro140
                Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                by Retro140
                So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                06-18-2023, 06:13 PM
              • Ierwin
                Philips 58PUS7805 Menu working but no/weird picture from video sources
                by Ierwin
                I got a 58pus7805 that shows some weird behavior.
                The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                I managed to install the latest official firmware by holding the control button while plugging...
                03-10-2024, 12:50 PM
              • vf fa
                EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                by vf fa
                Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                01-31-2024, 01:40 PM
              • tusiime
                How to access Vizio m652i-b2 service menu
                by tusiime
                The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
                So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
                Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
                09-15-2023, 09:57 AM
