Lg 32le4500
  • pintail120
    • Dec 2021
    • 3
    • United Kingdom
    Lg 32le4500
    I use to repair TV's for my bread and butter but now do it as a hobby. I have the above tv from a friend for repairs. When the TV is turned on cold it comes on ok, I have set the unit to display the demo screen and it will happily continue to do this for hours and then the relay in the PSU will start turning on and off repeatedly. If I check the on/off voltage from main board to turn the PSU you, it is fluctuating. The back light also turns off. however if I partially remove the riser to the back light the backlight turns on, but the screen is blank. If it turn the set off and leave it for 45min its turns on again and is fine. I have replace ALL the electrolytic caps in the PSU, not sure where to look next ? could it be the main board ? are there any more electrolytics I could have missed or is it something else ?
    thanks in advance for any help
    kind regards
    Gavin
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Lg 32le4500
    Have you tried pressing on processor to see if if stabilizes?
    • diif
      • Feb 2014
      • 6978
      • England
      Re: Lg 32le4500
      Yeah, i also suspect a BGA issue.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Re: Lg 32le4500
        It is a bga issue. A proper re- balling will cure it.
        • diif
          • Feb 2014
          • 6978
          • England
          Re: Lg 32le4500
          I'd just reflow it, a decent reflow will last years.
          • pintail120
            • Dec 2021
            • 3
            • United Kingdom
            Re: Lg 32le4500
            thank you kindly for all your suggestions.
            Any nice tutorials you can recommend on bga reflow techniques ?
            • dskall
              • Oct 2016
              • 2905
              • usa
              Re: Lg 32le4500
              I don't know of any actual reflow videos. Reflow implies that the solder is molten. All the "reflows" I've watched are just heating the board with flux to clean the oxide from the broken solder joints.
              • diif
                • Feb 2014
                • 6978
                • England
                Re: Lg 32le4500
                Reflowing is melting the solder. Some of the balls crack due to thermal expansion and contraction over time, mainly due to the lack of lead in the solder that allowed a little bit of flex.
                Reballing replaces the lead free balls with leaded ones that should provide a longer lifespan.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Re: Lg 32le4500
                  Can you suggest a video of a real reflow?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Re: Lg 32le4500
                    I haven't watched one for years since I bought my rework machine.
                    They will look like the videos you are watching but without the stupid "cleaning oxidization from broken joints" comments and more "it's to reflow the cracked balls" comments. They have a profile that melts solder and they might nudge the chip to check the solder is liquidious and watch it spring back.
                    OP, There is a great thread on here with some decent home reflowing, use the search feature along with my username as I know I was in it, you should be able to find it.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      Re: Lg 32le4500
                      https://www.badcaps.net/forum/showth...home+reflowing
                      • VitalComputing
                        • Dec 2021
                        • 29
                        • Ireland
                        Re: Lg 32le4500
                        Apologies, need to post to activate my posting of new threads.
                        • Stephen
                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                          by Stephen
                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                          03-15-2024, 09:37 AM
                        • www
                          LG L192WS-BN backlight turns off after 1 second
                          by www
                          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                          03-24-2024, 05:26 PM
                        • zklgfs
                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                          by zklgfs
                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                          Today, 02:14 PM
                        • andrhouseolly
                          Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                          by andrhouseolly
                          Hi.
                          I kindly ask you to help me solve the problem.
                          Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                          The board turns on, there is no image.
                          Read more. When the power supply is connected, the front panel indicators light up briefly.
                          When you press the power button, the button indicator lights up. The board works
                          there is no image, there is no matrix initialization, there is no image on HDMI.
                          When turned on, the fans do not spin, but when they warm up they start spinning.
                          When you turn off the button, the fans spin up to full speed for a short...
                          05-11-2024, 03:14 PM
                        • Egidio85
                          Samsung UE55F8000SZ Turns on and off immediately
                          by Egidio85
                          good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                          This defect happens continuously, hearing the classic click of the relay every time.
                          Power supply board BN44-00636B
                          disconnecting the mains and lamps from the power board always causes the same problem.
                          Is it normal that without anything connected this power supply turns on and off cyclically?
                          any suggestions on what to check?
                          thanks in advance
                          03-11-2025, 12:45 PM
