Vizio E550I-B2E
  • Super360
    • Jul 2016
    • 243
    Vizio E550I-B2E
    Hi everyone I have a set here that wont turn on at all. It has a white standby light but when you press power it acts like it wants to turn on by the light going off but nothing. You guys have any suggestions a tested the led strip with a led tester all is good there. So Now I'm wondering if its the psu, mainboard or tcon? thanks guys. I will upload pics of anything you guys want no problem.
  • lotas
    • Jan 2016
    • 4805
    • Russia
    Re: Vizio E550I-B2E
    Most likely the same problem, to solder the plug
    https://www.youtube.com/watch?v=paeXXLvQhCk
    https://www.youtube.com/watch?v=6u315asn_OA
    • Super360
      • Jul 2016
      • 243
      Re: Vizio E550I-B2E
      Yes its funny I took out the boards to find the connector was completely loose omg problem fixed thank you. That was my issue not often in tv repair is it this easy and free. thanks guys.
      • lotas
        • Jan 2016
        • 4805
        • Russia
        Re: Vizio E550I-B2E
        Yes, along the way, this is their typical malfunction.
        • handsworth
          • Oct 2015
          • 174
          Re: Vizio E550I-B2E
          Easy Peezy, I've found or bought many of these for pennies and fixed for nothing. Glad you fixed it.
          • Super360
            • Jul 2016
            • 243
            Re: Vizio E550I-B2E
            Good way to make some extra money for sure thanks guys.
            • ajshoe
              ajshoe
              • Dec 2012
              • 477
              • usa
              Re: Vizio E550I-B2E
              just found one of these on curb. WOW - what an easy fix. So what makes the connector solder joints go bad ? Is there a way to make sure this doesn't happen again ? Obviously this board was made CHEAP. horrible soldering on connector and rest of board.
              • Super360
                • Jul 2016
                • 243
                Re: Vizio E550I-B2E
                I took out both boards and resoldered both the male and female connectors probably bout 8 through hole on each connector just resolder the entire both connectors with FLUX AND GOOD LEAD SOLDER. finish with ipa alcohol cleaning tooth brush. Tighten all the ground screws in tv as well
                • ajshoe
                  ajshoe
                  • Dec 2012
                  • 477
                  • usa
                  Re: Vizio E550I-B2E
                  did all those things and soldered xformer pins also. curious why connector pins go bad.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Re: Vizio E550I-B2E
                    The design of the connector and lead free solder along with thermal expansion and contraction.
                    Did you remove all of the old solder or just added new leaded?
                    • ajshoe
                      ajshoe
                      • Dec 2012
                      • 477
                      • usa
                      Re: Vizio E550I-B2E
                      added leaded solder. I should have removed the lead-free solder. I did touch up all the connectors and xformer. Its an easy access - probably have to do it again. seems like connection between boards should have been a short cable
                      • x_orange90_x
                        Vizio E550i-A0 no power, no standby light
                        by x_orange90_x
                        I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                        11-20-2023, 09:49 AM
                      • p-top
                        Vizio, E60u-D3, no standby light, no ps_on
                        by p-top
                        Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                        main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                        PS voltages
                        1 VSNS -2mV
                        2-5 LED-OUT -2mV
                        6-10 GND -2mV
                        11 +16VS 16.29V
                        12 AC-DET 3.929V
                        13PS-ON -3mV
                        14 +16VS 16.29V
                        15 +16VS 16.29V...
                        11-27-2023, 10:44 AM
                        Lithonia Lighting versus Light of America Compact Fluorescent product quality
                        I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                        I also have back when Light of America had these light bulbs available for yard lights
                        The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                        While the Lithonia lighting fixture has all most certain bulb failure
                        So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                        I have only had this light fixture for not more than a year if it...
                        07-02-2023, 03:45 PM
                        LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                        This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-07-2024, 03:40 AM
                        LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                        This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 09:10 PM
