Any thoughts on this one ?
  • brianbelfast
    • Jun 2010
    • 29
    • Northern Ireland
    This one hasn't arrived with me yet, so I only have this photo to go on.
    I was thinking poorly seated left T-con ribbon but I'm not convinced that the fault is exactly 50/50 of the screen. It may not even have a separate T-con board.
    It's a Toshiba, and I'm guessing 43". Sorry no model number as yet.
    Any thoughts ?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Any thoughts on this one ?
    It looks like a solarized image but only half screen which I have not seen before.
    What is the model number?
    • dskall
      • Oct 2016
      • 2905
      • usa
      I would defiantly reset cables to panel. I don't thing bad gamma chip can only effect one side.
      • CityZen
        • May 2014
        • 40
        According to a "how to fix LCD problems" video I saw recently, that particular issue could involve anything from the main board to its connection to the T-con board to its connection to the panel. Data is getting lost along the signal path somewhere.
        If you can bring up a service menu test image, you can rule out the T-con board and downstream of it. Either way, it's a good idea to check out all the cable connections.
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • netgearnetgear
          TCL 43S423 TCON OR PANEL FAULTY???
          by netgearnetgear
          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
          08-20-2025, 06:04 PM
        • alltvrepairs
          Lg TCon test pins for screen test
          by alltvrepairs
          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
          Appreciate your help....
          06-13-2025, 06:33 AM
