Any thoughts on this one ?
  • brianbelfast
    • Jun 2010
    • 29
    • Northern Ireland
    This one hasn't arrived with me yet, so I only have this photo to go on.
    I was thinking poorly seated left T-con ribbon but I'm not convinced that the fault is exactly 50/50 of the screen. It may not even have a separate T-con board.
    It's a Toshiba, and I'm guessing 43". Sorry no model number as yet.
    Any thoughts ?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Any thoughts on this one ?
    It looks like a solarized image but only half screen which I have not seen before.
    What is the model number?
    • dskall
      • Oct 2016
      • 2905
      • usa
      I would defiantly reset cables to panel. I don't thing bad gamma chip can only effect one side.
      • CityZen
        • May 2014
        • 40
        According to a "how to fix LCD problems" video I saw recently, that particular issue could involve anything from the main board to its connection to the T-con board to its connection to the panel. Data is getting lost along the signal path somewhere.
        If you can bring up a service menu test image, you can rule out the T-con board and downstream of it. Either way, it's a good idea to check out all the cable connections.
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • netgearnetgear
          TCL 43S423 TCON OR PANEL FAULTY???
          by netgearnetgear
          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
          08-20-2025, 06:04 PM
