One vertical green line on my AQUOS LC-70LE740E TV
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4543
    • Italy - Milan
    #41
    Re: One vertical green line on my AQUOS LC-70LE740E TV
    You must search the forum how to attach photos, you doesn't in the right way, for the rest it means that the cof itself is damaged or the cof terminal is burnt, nothing to do sorry.. apart touching the screen glueing..
    • hoot
      • Nov 2021
      • 28
      • Global
      #42
      Thank you very much, it was worth a shot and I gained alot of experience. What do you mean by "screen glueing"?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4543
        • Italy - Milan
        #43
        sorry, i was referring to an advice from another user to touch the flat with the iron on the the part glued to the glass panel
        • hoot
          • Nov 2021
          • 28
          • Global
          #44
          Touch it on that surface?
          I hope I can gift the TV to someone local. On local listings people are asking quite some money for TVs that are more damaged than mine. Is there still any value in a TV like this?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4543
            • Italy - Milan
            #45
            yes touch there. I don't know which is the cost of that tv, also tv seems to cost much less in your country than mine..
            • hoot
              • Nov 2021
              • 28
              • Global
              #46
              What would a 70" 1080p made in japan TV with that defect go for in your country, roughly speaking.
              Okay I can heat the contact between the flex and the screen. Should I heat the connection between flex and PCB first?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4543
                • Italy - Milan
                #47
                I don't remember well, maybe about 150-160 euro, since here no more than 55 are normally used, i guess a full working one is about 300 euro. Today's Sharp 65 tv brand new costs 770 euro but are chinese tv rebranded, your is a true Sharp, so maybe 850 is the starting price, about 420 used if 5 years max , i don't know the years, so 210-230 faulty. Every 5 years price halfen.
                No.
                • hoot
                  • Nov 2021
                  • 28
                  • Global
                  #48
                  Thanks again, for all the information.
                  I will not heat the flex to pcb connection. I will heat the connection between the flex and the screen. If that won't fix it and the TV remains functional apart from the green line I will try to sell it for 100 bucks.
                  • hoot
                    • Nov 2021
                    • 28
                    • Global
                    #49
                    Unfortunatly that did not work in may case. Thanks again for all the help. It was worth a shot and I gained quite a bit experience. Im gonna sell the TV as defective.
                    • cubytus
                      Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                      by cubytus
                      Hi to all,
                      I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                      I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                      Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                      01-10-2024, 01:26 AM
                    • otaku_nut
                      Vizio E701i-A3 fixed but now has red vertical line
                      by otaku_nut
                      Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                      08-19-2025, 06:11 PM
                    • TrueSword88
                      Kogan - KALED65XU9220STB - Blue Vertical Line
                      by TrueSword88
                      Hi all.
                      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                      The line just happens to coincide with the end of COF and start of the next COF (attached).
                      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                      Hoping to fix...
                      05-05-2023, 04:28 PM
                    • almarhum
                      To fix laptop screen vertical line by working on its EDP cable
                      by almarhum
                      Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                      As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                      05-07-2024, 02:12 PM
                    • mrsith
                      Samsung UE58TU7100K - no picture, vertical line
                      by mrsith
                      Hi.
                      Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                      This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                      Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                      02-07-2023, 11:18 AM
